How to simulate a pipe flow with a recirculating loop? |
June 25, 2014, 07:40 |
Jing Shi
Hi everyone,
Could anyone give me some instruction on simulation of a pipe flow (the main flow) with a recirculating loop (secondary flow)? The physical problem is described in the attached figure. The oil-water mixture flows from the left to the right hand. It is sucked by a pump (at a given rate downstream) and is re-injected to the front through a number of small jets. To me, there are two inlets and outlets. Is it possible to simulate this process using FLUENT? Any instructions are appreciated! Regards, Jing |
Why Differences between tetrahedra polyhedra and prism mesh pipe flow computation with sonicLiquidFoam | chnrdu | OpenFOAM Running, Solving & CFD | 5 | May 7, 2018 03:23 |
Pipe flow heat transfer | feedq | FLUENT | 10 | November 26, 2014 08:23 |
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC | Endel | OpenFOAM Running, Solving & CFD | 3 | September 11, 2014 16:29 |
Steady pipe flow mean velocity higher than inlet velocity | anita | OpenFOAM Running, Solving & CFD | 7 | September 25, 2012 05:35 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 13:19 |
