Analytical modeling
Old   July 9, 2007, 11:11
Default Analytical modeling
Dave
Hi All,
I have to analytically model gas (nitrogen) flow in a pipe for my final year project. I am not sure where to start or which methods to use.
Can someone give me an idea on how to start this work - for example which questions should i be asking and which methods should i use?
Thanks for your help,
Dave
Old   July 12, 2007, 04:50
Default Re: Analytical modeling
Dave
Is this a really tough project or is my question badly put?
Does anyone know what assumptions should i start with?
Thanks!
Old   July 13, 2007, 13:24
Harish
Do you want to do it analytically or can you do numerical simulation? Analytical modelling might restrict the kind of problems you might work on?.Ok assuming you are working on a circular pipe flow,you can look at the paper of langhaar for analytical expression for the velocity and pressure before the flow becomes fully developed.Then for fully developed flow its just the poiseulle flow.Another thing that you can work on is developing some kind of asymptotic solution applicable for a wide variety of geometries.Another option might be modelling partial slip flow in micropipes?.
Old   July 24, 2007, 05:33
Dave
Hi Harish,
Thank you for your reply and sorry for my delay. I plan to do both analytical and numercial modelling of the flow in a circular pipe. Can you give me the name of the paper by Langhaar?
Thanks Dave
Old   July 24, 2007, 11:34
Harish
Steady flow in the transition length of a straight tube HL Langhaar - J. Appl. Mech, 1942.
Good Luck
Old   July 24, 2007, 12:31
Dave
Thanks Harish,
I'm finding it difficult to get this paper, i don't suppose you have an copy or a link to a source?
Regards, Dave
Old   July 24, 2007, 13:18
Harish
I got the paper as a printed copy during one of my courses.I'm not sure of its availability online.
comparison with analytical results (1D)and(3D) CFX Rogerio Fernandes Brito FLUENT 1 December 2, 2012 06:12
comparison with analytical results (1D)and(3D) CFX Rogerio Fernandes Brito CFX 2 October 28, 2008 20:26
May Focus Area: Turbulence Modeling Jonas Larsson CFD-Wiki 0 May 2, 2006 11:48
Modeling Flow/Saturation/Absorption in Fibers Gene Dougherty Main CFD Forum 0 June 6, 2003 14:49
CFD Modeling of Two-phase Flow in Small Dia.Tubes Eric Poindexter Main CFD Forum 2 September 22, 2000 09:21
