High speed gas-gas separation in a centrifuge-----
Old   August 28, 2007, 04:55
Default High speed gas-gas separation in a centrifuge-----
Kruger
Hi there,
I am looking for more info on the CFD modelling of the gas-gas separation process in a centrifuge. The design is proposed to be a very high-speed unit, and we are conducting some prelims into using CFD to model the design.
Is it safe to assume that most commercial codes can model this type of problem, and what are the big issues in the field?
Any pointers to other sources of info are more than welcome.
regards, Kruger
Old   August 28, 2007, 05:07
Default Re: High speed gas-gas separation in a centrifuge
Hrvoje Jasak
Very interesting - would this by any chance be a supersonic centrifuge, with two gasses of very similar density and lined up in a very long cascade? Say, about 3000 or so connected in a series?
Old   August 28, 2007, 05:18
Kruger
I guess it is possible considering the speed of rotation that was mentioned. It is not yet clear whether the units will operate in cascade or not.
Old   August 28, 2007, 08:25
Default Re: High speed gas-gas separation in a centrifuge-
Bart Prast
See Uranium/Plutonium enrichment. Might be classified information. Problem is that trying to separate two perfectly mixed components against the diffusion will be hard in CFD. It is not exactly a two-phase calculation, where you will need a lengthscale (bubble size, droplet size) to calculate the separation efficiency. People who know this stuff are probably reluctant to "share" their knowledge.
My two cents
Old   July 12, 2010, 16:00
Default Any progress?
Hunter
HFonten1 is on a distinguished road
I've just started working OpenFOAM to solve this same problem. Has anyone made any progress on this?
HFonten1 is offline   Reply With Quote
Old   October 25, 2016, 04:11
harshawardhank
harsha_kulkarni is on a distinguished road
which solver u r using
rhoCentralFoam or else
at higher rotation pressue and velocity not showing good result.
harsha_kulkarni is offline   Reply With Quote
DPM and High speed air flow John FLUENT 0 January 15, 2008 11:17
high speed flow with air dissociation Victoria Main CFD Forum 0 May 4, 2006 06:46
High speed flows Raj FLUENT 4 January 10, 2006 04:14
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
High speed bubbles dynamics Rune W. Time Main CFD Forum 2 June 28, 1999 10:22
