Steady needs unsteady.
Old   September 21, 2007, 04:50
Default Steady needs unsteady.
nico
The flow i am looking at has a fair bit of separation on a foil (3D) (around 15 % of the foil).
If solved with a steady solver, * k-eps, 2nd o on momentum: no convergence on the residuals, 'convergence' of the forces * SST, 2nd o on momentum: no convergence on the residuals, oscillation of the forces * k-eps, 1st o on momentum: convergence on residuals and forces.
So far so good, it's was I expected. All forces results look similar. (average of oscillation for SST)
Now if i switch to the unsteady solver, after around 20s the flow becomes steady: forces are constant, and flow characteristics are steady.
Obviously my unsteady calc takes 'much' longer to compute, why do I need to run this case in unsteady to reach steady state? I have also tried to start from the 1st order case and to go 2nd order when converged without better success.
Any comments are more than welcome.
Regards,
Nico
Unsteady DPM with steady solver elobb FLUENT 4 December 16, 2021 03:54
steady to unsteady wlt_1985 FLUENT 6 December 4, 2010 16:17
steady or unsteady DPM ??? Marina FLUENT 5 July 5, 2006 04:52
Turbulent: Steady or Unsteady: confusion prem FLUENT 0 March 30, 2006 10:40
steady or unsteady? (in dpm) winnie FLUENT 1 April 28, 2003 11:30
