convergence
Old   September 26, 2007, 23:16
Default convergence
rsi
What should we do if 2 out of 10 CFD models do not converge? We need to compare CFD results amongst all 10 cases but 2 of them not converged. If we change under-relaxation factors for 2 of these, will our comparison be valid? What do people normally do when encounter this problem?
Old   September 28, 2007, 08:08
Default Re: convergence
sidd
Your final result should not depend on relaxation factor. For rectifying convergence problem, have look on the poorley formed / diverged solution, and try to find regions of unrealistic numerical values of physical parameters, for your case of application. That can give you an idea for reason of divergence.
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
problem with Min/max rho tH3f0rC3 OpenFOAM 8 July 31, 2019 09:48
Force can not converge colopolo CFX 13 October 4, 2011 22:03
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
Defect correction and convergence ganesh Main CFD Forum 4 June 30, 2006 14:20
