October 6, 2014, 11:48 |
Points Per Wavelength
Issac Mamed
I am trying to find the grid points per wavelength PPW requirement to achieve a phase speed error less than 0.1 percent for sixth order non compact and compact centered approximations to a first derivative. I looked everywhere but cannot find the relationship between PPW and phase speed error and also how it relates to the Taylor Series expansions in the non compact and compact schemes. Please help me out. Thx Issac |
October 6, 2014, 17:16 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
Therefore you have the exact derivative f'(x) = ik f(x) and, on the other hand, a generic discrete operator Dn for the derivative will give you Dn f(x) = ik_eff f(x) being k_eff the resulting (can be also a complex number) modified wavenumber. In conclusion, the local truncation error can be written as L(x) = (d/dx - Dn) f(x) = i (k-k_eff) f(x) and you want to minimize k-k_eff. I suppose that one can start from the Nyquist theorem that says the minimum waveleght described on a grid needs at least of three grid points. So you can start checking the error for several choices (that is for several k_eff)... |
[snappyHexMesh] .STL: non-closed manifold surface | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 32 | November 25, 2016 03:15 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
[DesignModeler] DM's JScript: FPoint()'s GetPoint(i) function picks points backwards? | ANT | ANSYS Meshing & Geometry | 2 | July 23, 2012 15:25 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
