October 21, 2007, 02:06 |
Experimental data on transition
I am solving transitional flows and I need some Experimental data to validate my model. Where should I go to find the experimental data on transition? The compressible data is preferable.
Thanks in advance. |
October 23, 2007, 07:55 |
Re: Experimental data on transition
this is a very general question! there are quite a lot of experimental and DNS data on transition which has been done during decades but it mostly depends on the case you are dealing with at the moment. If you specify what you are working on now, it might be more clear...
October 24, 2007, 03:13 |
Hi Hatef,
Thanks for your reply. My work is focus on transitional flows in turbomachinery. The available experiment data is always on low speed but I want get some compressible data. |
Tecplot. add experimental data into a mesh | Alejandro | FLUENT | 0 | December 10, 2008 07:08 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 17:27 |
Looking for the experimental data | COLOPOLO | Main CFD Forum | 2 | January 28, 2004 23:38 |
Simulated data vs. experimental data | moiami | FLUENT | 0 | December 19, 2002 01:03 |
Experimental data for fence at low Reynolds number | Kim Bindesboll Andersen | Main CFD Forum | 1 | September 26, 2002 13:54 |
