Hypersonic problem
Old   October 28, 2007, 09:20
Default Hypersonic problem
Subramani Sockalingam
What I am trying to do is to find the solution where pressure, temperature and Mach number are 8.1757 Pa, 227 K and 22.41 (freestream conditions). I started with Mach 2 and increased the Mach number using the same pressure and temperature. At Mach 8 the absolute pressure was limited to the minimum 1 in a number of cells and the Mach number at some point in the domain became 90. Why would this happen? I am running a 2D inviscid implicit density based model.
Thanks, Subramani
conduction problem venkataramana OpenFOAM 3 December 1, 2013 07:30
Hypersonic problem Subramani Sockalingam FLUENT 4 December 12, 2007 07:57
CFL for explicit hypersonic problem Subramani Sockalingam FLUENT 1 October 29, 2007 05:05
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
