air properties - heat expansion?
Old   November 25, 2007, 08:52
Default air properties - heat expansion?
phsieh2005
I am doing a natural convection (air) calculation using Boussinesq approximation. The temperature ranges from 6 degree C to 37 degree C.
What reference temperature and heat expansion coefficient should I use for a range of temperature? Is there any website where I can find the values? Thanks!
phsieh2005
Old   November 25, 2007, 09:17
Default Re: air properties - heat expansion?
momentum_waves
A thought:
Locate an equation for coefficient of thermal expansion - if not a perfect gas. As I remember, for a perfect gas,
beta=1/T (where T=absolute temp [K])
Let the simulation compute beta as it determines the T field.
mw...
(www.adthermtech.com/wordpress3)
Problem with buoyancy and heat generation Jaguar CFX 8 May 12, 2011 18:54
heat conducting in a solid domain Rogerio Fernandes Brito Phoenics 0 March 18, 2008 17:23
heat conducting in a solid domain Rogerio Fernandes Brito Siemens 0 March 18, 2008 17:23
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
AIR molecular properties Julie Polyakh Siemens 3 January 5, 2002 16:25
