Run-TIme Optimizations
Old   November 13, 2014, 00:58
Default Run-TIme Optimizations
Shabir Mohamed
Shabirmean is on a distinguished road
What Optimizations can I do to reduce the runtime without effecting the correctness of the numerical values of a solved case?
Where are places I need to look into?
What should I be changing and consider making changes to?
Shabirmean is offline   Reply With Quote
Old   November 14, 2014, 12:20
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
How could we answer without any detail? Programming Language, application, etc.
At this level the only obvious answer is: use a profiler, it will tell you.
sbaffini is offline   Reply With Quote
Old   November 14, 2014, 12:35
Shabir Mohamed
I am sorry. It is a case run in OpenFOAM which is written in C.
Software used: OpenFOAM CFD
Case: I am trying to solve the Shallow Water Equations using the OpenFOAM built in solver shallowWaterFoam.
Grid size: 70 x 40 square meters.
Iv started with a fine mesh with 20 cells per meter and have reduced it to 5 cells per meter for run-time reduction. Reducing it further may affect the accuracy of the output!!!
Current Hardware: Intel Core i7-3770 ---> 3.4 Ghz x 8
Graphics: Gallium 0.4 on NVE7 Cache: 3MB
Can you suggest some best choices for profiling packages?
Thanks
optimization, real-time, runtime modifiable, solvers
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 16, 2019 23:12
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
time step directories naming issue Andrea_85 OpenFOAM 3 April 3, 2014 08:38
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 07:47
