oscillating airfoil in an inviscid fluid flow |
December 8, 2007, 02:15 |
How can we apply pressure boundary condition on airfoil surface oscillating in an inviscid fluid flow?
December 8, 2007, 05:30 |
Re: oscillating airfoil in an inviscid fluid flow
Why do you need a pressure boundary condition, not the standard vanishing normal velocity on the airfoil?
December 8, 2007, 06:36 |
I want to solve unsteady Euler equations using C-type mesh. that's why I need pressure boundary condition on the airfoil surface.
December 8, 2007, 11:53 |
the pressure BC can be obtained from the expression(latex math): {\partial p \over \partial n}=-\rho \vec{a}_b \cdot \vec{n} where \vec{a}_b is the acceleration of the body and \vec{n} is a vector normal to the surface.
December 10, 2007, 01:17 |
the equation you mentioned must be applied in the fluid and we know that fluid particles slip on the airfoil surface and for slip condition we know that acceleration of body is not equal to fluid particles !
December 10, 2007, 05:25 |
December 10, 2007, 08:07 |
You apply this to get the pressure and then a condition on the normal velocity(ie that they are the same for the fluid and structure). Look at any papers which deal with fluid-structure interaction and the Euler equations.
Inviscid flow solver | luca_g | OpenFOAM Running, Solving & CFD | 2 | Today 08:43 |
flow around an airfoil | Nicola | FLUENT | 1 | August 15, 2013 19:31 |
benchmark: flow over a circular cylinder | goodegg | Main CFD Forum | 12 | January 22, 2013 11:47 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
