Mass matrix
Old   January 30, 2008, 11:01
Default Mass matrix
Mehmood ur Rehman
I am solving Navier-Stoke problem. If i using tetrahedron, i get negative diagonal elements in the mass matrix. any idea to overcome this problem.
Old   January 30, 2008, 12:56
Default Re: Mass matrix
CFD newbie
Yes use Hexa. Hope it helps!
CFD newbie
Old   January 30, 2008, 15:47
Mehmood ur Rehman
I have already used hexahedrons and i have no problem. i need help in tetrahedron. Can give me pointer to literature, where these kind of problems are solved. cheers
Old   January 30, 2008, 18:16
CFD newbie
Sorry Rehman i would have helped if i knew the answer. You did not elaborate your problem properly either. Help Guyssssssss!
Old   January 31, 2008, 03:31
Mehmood ur Rehman
Actually i use diagonal of the velocity mass matrix in LSC preconditioner. In tetrahedron, i get negative values on the diagonal that reduces the convergence rate. i have no problem in hexahedron. my be this is enough to elaborate my problem
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
OpenFOAM version 1.6 details lakeat OpenFOAM Running, Solving & CFD 42 August 26, 2009 21:47
Newton Cotes for mass matrix Mehmood Main CFD Forum 1 May 22, 2008 07:17
How To Input Mass Sources In a Porous Matrix? Carlos FLUENT 0 February 23, 2006 11:03
