Extracting element number with respect to Nodes |
January 23, 2015, 08:13 |
sagar
Rep Power: 12 |
I have exported the .csv file with the nodes number and other parameters from the export command in the file menu. However I want the file which also mentions the Element ID (number) infront of the Node number. So, it is possible in CFX? because I need to extract the data of Node numbers, Element number associated with the Node and parameters.
January 27, 2015, 16:56 |
Rep Power: 143 |
To get the node numbers you just select the Node Numbers option on the export tab.
Have a look on the other options available on the export tab but I do not think they will help you. I do not think you can get element numbers easily. You will probably need to use some user fortran to get this. |
January 28, 2015, 04:11 |
sagar
Rep Power: 12 |
Mr. Horrocks thanks very much for reply. Yeah you are correct there is no option to get the details of element ID. However I found the answer to my question in CFX reference guide. In section 3: Mesh and Result export API, in that sample code is given explaining how to get the required data. so, I think I need to understand and write code as per my requirement.
however thanks a lot. |
element number, nodes and .csv |
[ImmersedBoundary] Immersed Boundary Method in OpenFOAM-3.1-ext | miladrakhsha | OpenFOAM Community Contributions | 106 | July 3, 2023 10:26 |
decomposePar no field transfert | Jeanp | OpenFOAM Pre-Processing | 3 | June 18, 2022 12:01 |
timeVaryingMappedFixedValue: large data mapping on complex inlet boundaries | vkrastev | OpenFOAM Pre-Processing | 7 | June 2, 2016 15:50 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
Interpolation (Number of mapped nodes) | Sam | CFX | 3 | January 6, 2008 19:51 |
