What is the advantage of using ideal gas in CFD simultion..? |
January 30, 2015, 09:25 |
SIVAKUMAR
Rep Power: 12 |
which problem physics i should/should not consider the ideal gas as my medium...?
January 30, 2015, 13:41 |
Lane Carasik
Rep Power: 14 |
Use ideal gas when your fluid can be approximated as an ideal gas, don't use the ideal gas approximation when it isn't one.
January 30, 2015, 13:50 |
Rep Power: 14 |
Basically you want to use the model when your fluid is compressible in the ideal gas region of the material, usually low to medium pressures (encompassing atospheric for air). This is good if you want to capture bouyancy forces and density changes.
CFD in natural gas processing | s-rod | Main CFD Forum | 0 | December 13, 2014 16:25 |
Ideal Gas properties- Axial turbine-need help in linking temperature and pressure | Gowrav | FLUENT | 0 | June 15, 2013 04:50 |
Ideal Gas Mixture, non reacting | Ancioi | OpenFOAM Running, Solving & CFD | 5 | April 12, 2013 07:10 |
Periodic Interface (Ideal Gas) Massflow Control | Zigainer | CFX | 0 | July 25, 2011 11:43 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
