February 5, 2015, 10:01 |
Dynamic similarity: Heat Transfer
Rep Power: 17 |
Is there a formula that treats heat transfer and dynamic similarity?
E.g. If a human's surface temperature is 37ºC or a has heat flux of 56W/m^2, what equation can I use to find out the equivalent heat flux required for a submerged heated cylinder in a water tank to mimic a human at a reduced scale (1/20)? Equivalently I have a 25W heater in a quiescent water tank at 7ºC. What process/equations can I use to find out the equivalent heat output were a larger cylinder (1/20 ratio) in air? Does this make any sense or have I got the concept of dynamic similarity wrong? Image of cylinder |
dynamic similarity, heat transfer coefficeint, heat transfer modelling |
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff | swahono | OpenFOAM Running, Solving & CFD | 10 | October 15, 2018 05:43 |
Porous domain:Interfacial area density and heat transfer coefficient | l.te | CFX | 2 | May 17, 2014 23:45 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
Question on heat transfer coefficient!!! | Benny | FLUENT | 7 | June 7, 2005 09:25 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
