Flat plate CFD
Old   February 18, 2015, 03:22
Default Flat plate CFD
soria is on a distinguished road
Hi
I am trying to model the laminar flow past a flat plate and have 3 questions.
1) If I select a constant density and material under the material properties, does this mean that FLUENT is solving the incompressible governing equations? The solution should be comparable to that of Blasius (1908).
2) If I select ideal gas under the material properties, does this mean that FLUENT is using the compressible governing equations? The solution should be comparable to that of van Driest (1952).
3) I am using a symmetry boundary condition for the top of the rectangular computational domain, this imposes a slight streamwise pressure gradient on the laminar flow. Are there any other options I could use to ensure a zero streamwise pressure gradient?
Cheers
Soria
soria is offline   Reply With Quote
Old   February 18, 2015, 10:50
Troy Snyder
tas38 is on a distinguished road
Originally Posted by soria View Post
Hi
Cheers
Soria
1. Yes and yes
2. Yes and yes
3. I am not sure how the symmetry boundary condition imposed on the upper wall of
the computational domain (normal to the streamwise direction) results in a slight
pressure gradient in the streamwise direction? Seems as though the pressure gradient
may be due to the boundary conditions at inlet and outlet of the domain.
tas38 is offline   Reply With Quote
Old   February 19, 2015, 06:01
Cees Haringa
CeesH is on a distinguished road
Doesn't the symmetry mean that basically, you have a domain which represents a flow between 2 flat plates? The small streamwise pressure gradient would then be the pressure drop due to friction right?
Anyway, does the streamwise pressure drop significantly affect the solution?
an alternative may be using a 0-shear wall or a far-field fixed pressure...
CeesH is offline   Reply With Quote
Flat Plate Drag & Lift Joe Main CFD Forum 3 October 24, 2008 14:17
PIV - transitional flat plate flows MC Main CFD Forum 0 July 4, 2007 08:21
Turbulent Flat Plate Validation Case Jonas Larsson Main CFD Forum 0 April 2, 2004 10:25
Free convection flow over vertical flat plate Polly Main CFD Forum 1 February 11, 2003 13:25
Which is better to develop in-house CFD code or to buy a available CFD package. Tareq Al-shaalan Main CFD Forum 10 June 12, 1999 23:27
