March 12, 2008, 10:32 |
modeling of a bulk heater
Dear all. nowadays I control a temperature of a heater, the heater is consisting of a Bulk Aluminium and at its bottom there is the Coil Heater. When I apply the current to the Coil heater the temperature begins increasing when the power is switched of the temperature continue increasing till it reaches a maxima. then temperature decreases, while it decreases if the power is switched again it continu decreasing till reach a minima. and so on. Is this a form of inertia in the heater? I have developped many PID controllers that control Motor Speed, Flow, Pressure using MATLAB and VISSIM, i did that because i was knowing the modeling ( Transfer Function ) of the system i want to control, but now I could n't do that because i do n't know the Transfer Function of such heater...
How to model this heater? Is there any way to model it? Plz guide me in my PROBLEM. thanx in advance.. M.Shendy |
plot bulk temperature of fluid | mohammadkm | FLUENT | 4 | December 13, 2011 15:37 |
Reversed flow error with thin film heater | MK | FLUENT | 1 | February 12, 2009 10:26 |
May Focus Area: Turbulence Modeling | Jonas Larsson | CFD-Wiki | 0 | May 2, 2006 11:48 |
Modeling Flow/Saturation/Absorption in Fibers | Gene Dougherty | Main CFD Forum | 0 | June 6, 2003 14:49 |
CFD Modeling of Two-phase Flow in Small Dia.Tubes | Eric Poindexter | Main CFD Forum | 2 | September 22, 2000 09:21 |
