March 18, 2008, 12:03 |
reaction Rate
Hi;
I solved a combustion problem.My geometry was cylendrical. I used EBU-Arreius model that is minimum of ebu(eddy break up) and Arrenius model to calculate reaction rate . But in my postprocessing, temperature was almost everywhere low (between 400~500),whereas temperature should be greater than 2000.As soon as I used ebu(eddy break up) model , results tended to more logical temperetures. Nevertheless in literature it has been accepted EBU-Arrenius model , but in my code only EBU has logical results.Which model do you suggest?Why did it occur for my problem? Thanks alot for any help. |
Segmentation fault in running alternateSteadyReactingFoam,why? | NewKid | OpenFOAM | 18 | January 20, 2011 16:55 |
UDF for catalyst volumetric reaction, temperature overshoot though rate is small | elmcmaster | FLUENT | 0 | October 11, 2010 09:37 |
surface reaction rate with udf | yellow-stuff | FLUENT | 4 | January 29, 2010 12:53 |
UDF changing the rate exponent of a reaction | Stefan H | Fluent UDF and Scheme Programming | 0 | September 16, 2009 13:20 |
chemical reaction - decompostition | La S. Hyuck | CFX | 1 | May 23, 2001 00:07 |
