Turbulence models for jets issuing into a counterflow |
March 26, 2015, 08:43 |
Martin
Rep Power: 11 |
I want to simulate an array of 9 jets (diameter 0.8 mm, velocity: 0.2 m/s, oxygen) issuing into a counterflow (velocity 0.02 m/s, CO2). The inlet of the counterflow is in the top left-hand corner, the outlet is at the lower right-hand corner. The sidewalls are periodic. The Reynoldsnumber is rather low, about 12 for the inlet tubes. Do I need to use a turbulence model? Which would be the best one. And which model constants should I use? I observed differences for the stagnation point for different models. The Reynolds number is low, but I think there is still some turbulence and streamline curvature involved, especially in the mixing layer. Thanks for your help! |
March 26, 2015, 09:42 |
Matt
Rep Power: 17 |
Large Eddy Simulation.
March 26, 2015, 11:15 |
Martin
Rep Power: 11 |
I think large eddy simulation is beyond my available computation power. I calculate on a 4 processor desktop computer using Ansys Fluent.
The numerically predicted stagnation point is nearer to the injection point than the experimentally meassured. What justified changes can I make to the turbulence model to move the numerical stagnation point further away? |
March 26, 2015, 11:16 |
Matt
Rep Power: 17 |
Yes probably so...
I would maybe go with SST (a form of k-w). |
March 26, 2015, 11:19 |
Matt
Rep Power: 17 |
I am not sure I would look to change the turbulence model in any significant way.
If you have experimental data you can see which one gets you closer, but unless you have a very good understanding of how the changing constants will affect your model I wouldn't play around too much. You may cause more problems than you solve. |
March 26, 2015, 11:43 |
#6 | |
Filippo Maria Denaro
Rep Power: 71 |
on your 4-processor system, what is the finest grid you can use? This case seems resolvable in DNS ... |
March 26, 2015, 12:05 |
#7 | |
Martin
Rep Power: 11 |
I know...I just think that the cases the model was callibrated with might be far away from my 0.8 mm jet I use the model for. What do you think about a Reynolds number of 12? Normally that would mean no turbulence? Reynolds-stress Models opposed to others do account for streamline curvature right? I think this is important in my simulation, as the streamlines for the jets are bend by 180°. That's why I tried them at first. If I use k-w SST the streamline curvature would not be taken into account - so even if I got closer to the experimental data I would neglect an important physical phenomenon. |
March 26, 2015, 12:44 |
Matt
Rep Power: 17 |
Turbulence is always a part of the flow at some scale. Plus the boundary layer of the jet is going to mix as it diffuses and that mechanism (if I recall properly) was turbulent mixing.
SST isn't the best choice by anyone's measure. It will be better than k-e and standard k-w but it is known to over predict turbulence in high gradient regions (so near stagnation). What options do you actually have available to you? FMDenaro, please correct me if I am wrong, but if LES isn't an option due to resource availability DNS should be off the table as well, no? DNS requires resolution of all length scales and is even more computationally expensive than LES, or so I thought. |
March 26, 2015, 12:50 |
#9 |
Matt
Rep Power: 17 |
Also, is my understanding of SST flawed? I thought it was formulated to do a better job with curved flow than traditional k-w. Do I have that backwards?
March 26, 2015, 13:07 |
#10 | |
Rep Power: 71 |
indeed I asked for the finest grid you can use...Re=12 at the inlet is small, 4-processor system should be able to solve grids number O(10^6) |
March 26, 2015, 17:44 |
#11 |
If your Re is really 12, no matter what, any turbulence model is gonna give you garbage. It simply seems a laminar unsteady flow, there would no reason to simulate it as turbulent.
This, obviously, doesn't mean that the simulation is feasible... |
March 30, 2015, 13:36 |
#12 |
Martin
Rep Power: 11 |
So you mean I should try to simulate it as an unsteady laminar flow without any turbulence model? The Reynolds number is calculated using the tube diameter of 0.8 mm. Is this the right reference for this case?
March 30, 2015, 13:39 |
#13 | |
Martin
Rep Power: 11 |
I started an LES. I'll see wether it converges in a reasonable time |
March 30, 2015, 13:54 |
#14 |
Martin
Rep Power: 11 |
SST is some kind of a mixture between k omega and k epsilon. k omega near the wall and k epsilon in the free stream. All are first moment closures, meaning that according to the Bousinesqu hypothesis the Reynolds stress tensor is proportional to the mean strain rate....I thought as I have a reverted flow with a more complicated flow field I should take the Reynolds stress model.
March 30, 2015, 13:59 |
#15 | |
Martin
Rep Power: 11 |
I have a Desktop computer, 4 processor and Ansys 15 Workbench as available options. |
April 7, 2015, 18:33 |
#16 |
Sorry, but this post got lost and i couldn't see it anymore.
Yes, i mean "to simulate it as an unsteady laminar flow without any turbulence model", exactly. Which, you should be aware, is nothing different from DNS. Just that, in this case, there should be no inertial range... that is, your solution stays (mostly) "calm". The fact about RANS/URANS is that they assume the flow to be turbulent, fully turbulent. Which is not your case, at all (yes, inlet diameter and mean velocity should be the relevant parameters for the Re number). A more complicated model (e.g., Reynolds stress) does not add anything to this. In 2009 i could run 1Mln cells on the four cores of a Q6600 processor for enough time to do time statistics on a synthetic jet case (8 cycles, LES)... still, the job took 1 month. According to your processor, cache, RAM, code, you might be quite above that number. |
counterflow, jets, turbulence models |
different zones, different turbulence models | gmwsy | FLUENT | 5 | June 17, 2020 15:42 |
in k-epsilon wall function approach high Re turbulence models: question of velocity | romant | OpenFOAM Programming & Development | 6 | May 26, 2016 09:14 |
Y plus for various turbulence models | taram | CFX | 8 | December 16, 2013 11:44 |
Zero Equation Turbulence models | stefan.gracik | OpenFOAM Programming & Development | 3 | April 17, 2013 14:12 |
KOmega Turbulence model from wwwopenFOAMWikinet | philippose | OpenFOAM Running, Solving & CFD | 30 | August 4, 2010 10:26 |
