solving finite journal bearing problem by finite difference |
May 22, 2000, 05:16 |
As many people may know that the governing equation of liquid-lubricated bearing is the Reynolds equation, which is the reduced form of Navier-Stokes equations.
I can use Runge-Kutta method to solve the long and short bearing, but I can't for finite bearing. I mean the results when I solve in the direction of plus x axis and in the direction of minus x axis is not the same thing. I will try to use finite difference. Do anyone have the idea to suggest me? Thank you very much. |
June 2, 2000, 02:24 |
suggestion
Hai,
I would like to know if you are very specific of using finite difference technique. Why don't you solve the problem using some analytical technique? I shall be happy if I know the assumtions made in your problem too. |
March 19, 2015, 11:41 |
About Matleb Programe for reynold's equation solution by finite diffrence method
Suchit
Rep Power: 11 |
you have any matleb programme in which Reynold's equation is solved by finite difference method???????
i am doing work on this bus not getting any reference work for complete convergent and divergent shape for parabolic shape.... My mail id : shahsuchit007@gmail.com |
March 19, 2015, 11:45 |
Suchit
Rep Power: 11 |
March 20, 2015, 22:49 |
Troy Snyder
Rep Power: 18 |
Solving the Reynolds equation for a finite journal bearing via finite differences
is very common. I refer you to the text by Pinkus and Sternlicht as well as the "Journal Bearing Data Book" by Someya. Both books outline discretization of the Reynolds equation. Also, the book "Numerical Lubrication by Lubrication" by Huang has a number of codes. They are written in FORTRAN. http://www.wiley.com//legacy/wileych...tion/code.html If you don't like either reference, central differencing all the pressure derivatives and upwind differencing the Couette should be successful. The resulting linear system can then solved by your choice of linear solver without any trouble (Reynolds is essential Poisson's eqn.). |
March 21, 2015, 03:27 |
for piston ring in ic engine for flow separation by finite diffrence method in matleb
Suchit
Rep Power: 11 |
thank you for replay but required solution of reaynold's equation in matleb only by finite diffrence method...for parabolic ring sliding on liner surface by flow separation...
March 29, 2015, 08:09 |
Suchit
Rep Power: 11 |
its very nice book but have full coding in FORTRAIN....same book required in MATLEB...
transsonic nozzle with rhoSimpleFoam | Unseen | OpenFOAM Running, Solving & CFD | 8 | July 1, 2022 06:54 |
Floating point exception error | Alan | OpenFOAM Running, Solving & CFD | 11 | July 1, 2021 21:51 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
Problems with simulating TurbFOAM | barath.ezhilan | OpenFOAM | 13 | July 16, 2009 05:55 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
