zero equation model for flat plate boundary layer
Old   June 17, 2008, 03:35
Default zero equation model for flat plate boundary layer
Amir
Hello, I want to solve a turbulent boundary layer over flat plate. I want to use zero equation turbulence model. In the equation for mixing length (l=ky(1-exp(-y+/A+)) how can I find y+ because there exists wall shear stress in the y+ relation. Is there any simpler way to calculate the mixing length?
thanks
Old   June 17, 2008, 04:09
Default Re: zero equation model for flat plate boundary la
Praveen. C
y+ = y u_\tau / \nu
where u_\tau is the friction velocity. It comes from
\tau_wall = \rho u_\tau^2
where \tau_wall is the shear stress at the wall and found from
\tau_wall = \mu du/dy
(y is assumed to be wall normal direction)
Old   June 17, 2008, 05:31
Amir
i wanna solve turbulent boundary layer eq. by finite difference method. should I write difference form of du/dy in \tau_wall = \mu du/dy? du/dy is velocity gradient at the wall, isn't it? How can I write the difference form of du/dy at the wall?
Old   June 17, 2008, 16:42
Praveen. C
Yes. Use a one-sided finite difference. Experiment with different finite difference formulae and see how the results change. You can compare your solution with experiments.
Old   June 18, 2008, 11:16
Amir
thanks alot
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Very technical question about solving wall boundary layer ... jlb001 FLUENT 6 December 27, 2014 05:56
Turbulent Boundary Layer on flat plate samygero ANSYS 2 May 31, 2011 09:53
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
Boundary Layer Noise Source Model Andrew FLUENT 0 January 12, 2009 22:47
