Rotating flow
Old   April 25, 2015, 03:16
Default Rotating flow
Artem
Tapoky is on a distinguished road
The task: axisymmetric problem, need to blow channel. A channel is a flow path between the rotor and the stator. The main question is how to apply to the input of the channel "twisted" the air flow?
The pressure difference between the inlet and the outlet is not great. The channel area is also not large. If air is perpendicularly to the entry, the flow rate at the input of only the average 2 m/s. So the settings at the input vector is useless. Tried to make the entrance area and used frame motion with the rotating speed, but it basically looks like a normal rectangle, respectively thread gets a twist in the wall layer and the core flow is still a major component of the axial velocity. Can you please tell how to solve this problem.
Tapoky is offline   Reply With Quote
Old   April 27, 2015, 17:00
Matt
fluid23 is on a distinguished road
I am guessing something got lost in translation here. It is very difficult to decipher what you are after.
Are you trying to find a way to set inlet swirl?
fluid23 is offline   Reply With Quote
Laminar flow simulation in rotating domain rahulv CFX 7 July 9, 2014 06:19
Flow past rotating cylinder sam.ho OpenFOAM Running, Solving & CFD 4 October 10, 2013 07:49
impinging jet flow on rotating disc trentar Main CFD Forum 0 October 5, 2013 04:30
Rotating flow through a construction EA1990 Main CFD Forum 0 July 13, 2013 10:49
Re: flow through a rotating serpentine passage Paulas CFX 0 January 23, 2009 22:01
