how to extend FSI 2D codes to 3D, need advises |
May 15, 2008, 03:28 |
How to make FSI codes with CFD and CCM in 3D case from the region of dynamics problems (explosions, impacts (km/sec) to vibration and static using the same Finite Volume simple, reliable and effective ? Need discussions and advices
Notations: High Order (second order) Godunov Type Finite Volume = HOGTFV Fluid Structure interaction = FSI Fluid Fluid interaction = FFI FLUID(state eq. #1) - Fluid(state eq. #2) Boundary = FFB Fluid - Solid Boundary = FSB Riemann's problem solver = RPS at first about my experience and results on 2D case for CFD, CCM and FSI and FFI which I am going to use for 3D 2.1. for fluids HOGTFV for moving Euler meshes on compact (3*3*3) stencil with algorithms of monotonicity, density resolution, avoiding of "carbuncle phenomena", the same order of accuracy (2 order) in the boundary cells (free boundary and etc.) 2.2. for solids HOGTFV for moving Euler meshes on compact (3*3*3) stencil with algorithms of monotonicity, the same order of accuracy (2 order) in the boundary cells (free boundary and etc.), accuracy is enough even for vibration simulation of plates and shells, (no viscosity from the boundaries). For plasticity and viscosity effects and etc. in solids the splitting algorithm (Kukudzhanov approach) is used, which is enough to keep the same 2 order. 2.3. For FSI (fluid solids coupling) or FFI (fluid#1 fluid#2 coupling) exact RPS is used (for FSI it is practically combining of two RPS (for Tate state eq. for fluids and elastic solver for Hook's law for solids) on the FSI boundary. The algorithm of the FSI or FFI in 2D (Lagrangian on the boundaries of domains, Eulerian inside of each domain) 2.3.1. RPS are realized on all boundaries (FF, FS and etc) 2.3.2. all boundaries are moved in normal and tangent directions with the velocities of these boundaries. 2.3.3. the new mesh is constructed on the new boundaries, it means that on the normal direction Lagrangian movement of the boundary line, for the tangent - Eulerian 2.3.4. the new Eulerian mesh in domains is constructed in accordance with the new mesh on the boundaries of the domains with the fluids and solids. 2.3.5. each domain with fluid or solids is solved in usual manner for moving Eulerian mesh (step from old to new mesh) advantages: good from acoustic case and vibration simulation up to explosive and impact (several km/sec) problems Problems: 1. even in 2D case if there are large deformation of the FFI or FSI, sometimes it is a problem to construct the mesh inside the domain 2. the approximation error grows because the mesh is not rectangular and changes a lot of 3. time step goes down from the stability requaments for such deformed mesh How to go to 3D case for FFI and FSI? This HOGTVF in 3D case is practically the same as for 2D RPS also practically the same For good accuracy for FSI and FFI it is necessary to detect and follow the FFB and FSB I see two ways of solution: 1 way: the same as in 2D Lagrangian movement of the FFB and FSB surfaces after appropriate RPS, then Eulirian movement mesh solver (all 5 items of 2D) Problems: 1. usual problem of 3D even generation of initial structured or unstructured mesh, the mesh inside the domain is a function of mesh on the domain's surfaces, this problem is huge and in some case too complicated and takes a lot of time 2.movement of the FF and FS surfaces after RPS and construction of the new mesh on the surfaces is possible to solve 3. to construct the new mesh inside domains as a function of the new moved surfaces practically is impossible for a lot of cases. 4. to solve 3D for moving Euler is a problem for Gasdynamics may be it is OK but for Solids the volume calculation errors will completely destroy the solution (the small change of the density from the HOOK's state eq. will change the stress tensor a lot of), So from my point of view it is impossible to make 3D codes similar to 2D with the same accuracy. 2 way: to use regular nonmoving rectangular Euler cubic mesh for fluids and structures and to detect and follow the surfaces of FFB or FSB advantages: 1. simple initial mesh generator, only surfaces between FF and FS and the value of the cubic. 2. nonmoving mesh - simple integration of equations 3. the approximation error are in accordance with the accuracy of the scheme 4. time step is OK Problems: How to calculate the movement of the FF and FS surfaces? my opinion: it is necessary to calculate in local adaptive to surface mesh not only the movement of the FF or FS surface, but the cells, which are closed enough to the surfaces (taking into account the hypebolicity of the problem), for example 2 boundary layers parallel to FF or FS. For this it is necessary 1. to construct local adaptive mesh on the FF or FS surface normal to the surface, this local mesh is to be formaly enough for the accuracy of the scheme for 2 adjacent cells on the left and 2 adjacent on the right of the FF or FS 2. to interpolate from the cubic mesh the parameters with the appropriate accuracy to this local mesh and solve appropriate RPS and integrate all the adjacent cells like in 2D with the movement in normal to the surface direction. 3. solve the clean cells (which do not need the boundary conditions) inside Fluids or Solids in nonmoving Euler 4. to construct the surfaces and to interpolate parameters to the cubic's centers from the adjacent to the surface and clean cells. I think in such manner it is possible to have the same accuracy as in 2D and simulate from acoustic and vibration up to explosions and meteor's (10km/sec) impacts and penetration. need critiques, ideas and advices with the 3way and etc. |
May 30, 2008, 04:08 |
nobody knows?
nobody knows?
Is it worth it? | Jason Bardis | Main CFD Forum | 47 | July 27, 2011 04:52 |
User-defined force transfer across FSI interface | vivekcfd | CFX | 7 | March 10, 2010 20:43 |
BCs in an FSI simulation of a flexble pipe | vivekcfd | OpenFOAM | 10 | January 8, 2010 04:14 |
fsi | sun | Siemens | 8 | January 19, 2009 23:17 |
Comparison of CFD Codes | Kerem | Main CFD Forum | 9 | May 9, 2003 04:29 |
