Navier Stokes Equations solved by commercial CFD codes |
September 8, 2015, 21:18 |
DB
Rep Power: 15 |
Apologies in advance for such a basic question. I tried to find an answer on other threads and online, but to no avail. So my doubt is like this : I think CFD codes in turbulent flows ( with some turbulence model) solve the viscous terms, including molecular viscosity, but I am not sure. My doubt is like this 1) Is my knowledge on this issue correct Take the example of a simulation with little or no inlet turbulence value specified 2) Do commercial codes switch -On and switch-off solving of viscous terms depending on the region. 3) How does it effect the calculation of internal flows (say flow in a enclosed chamber) and external flows ( say flow over an aircraft wing). Is there some efficient way by which the codes treat viscous terms to save computational cost. Thanks
-D.B |
September 9, 2015, 03:45 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
First of all, you should think of what formulation you want to adopt, RANS/URANS/LES are some possibility that a commercial CFD code offers to you |
September 9, 2015, 03:48 |
DB
Rep Power: 15 |
Lets say RANS, but how would it matter if its LES(other than Sub-Grid Scale modelling ofcourse) or URANS ?
-D.B |
September 9, 2015, 04:01 |
Rep Power: 71 |
September 9, 2015, 04:23 |
#5 | |
DB
Rep Power: 15 |
My main question still stands, do codes solve the molecular viscosity term at every grid point/region in the flow ?
-D.B |
September 9, 2015, 04:45 |
Rep Power: 71 |
The molecular diffusion is always solved for turbulent flow, implicit or explicit time integration is used. However, it is of magnitude that is disregardable almost everywhere if compared to the action of the turbulence model.
You need to resolve the boundary layer and that is depending on the grid generation not on the CFD code.... |
Navier stokes Equations in Unstructured Grid | Mh.R | Main CFD Forum | 4 | October 19, 2011 15:37 |
LBM Vs navier stokes equations in turbulent fluid flow modeling. | sharad_shevate | Main CFD Forum | 0 | August 3, 2009 01:25 |
CFD Codes | Jonas Larsson | Main CFD Forum | 5 | September 14, 1998 07:08 |
CFD - Trends and Perspectives | Jonas Larsson | Main CFD Forum | 16 | August 7, 1998 16:27 |
salary range | Frank Muldoon | Main CFD Forum | 7 | August 3, 1998 19:04 |
