is there any solution which can make CFD program stable? |
April 26, 2015, 22:20 |
garry
Rep Power: 12 |
Hi, everyone!
I recently use a CFD program to make simulation, but I found that my program is very unstable when I change some parameter, such as the grid. Mesh is the H-type, so there is not negative mesh, and the angle is not small--orthogonality is good. When I use the CFD software, there is no such problem before, and the solving speed and the convergency is both fast and good. So, I want to ask whether there is some method to make the CFD program stable. Is there paper to solve such problems? Thanks! Garry |
April 27, 2015, 01:48 |
shahrooz
Rep Power: 14 |
Are you using proper under relaxation factors?
April 27, 2015, 04:12 |
garry
Rep Power: 12 |
Thanks for telling me this point. When I use the software I know the under relaxation factors, but I have not changed it in my CFD solver program. This solver is an old one, and I am the only person who use it in my team.
I want to ask u where the under relaxation is used in the CFD program; is it in the residual subroutine or the flux update subroutine or any other one? thanks very much! |
April 27, 2015, 04:20 |
garry
Rep Power: 12 |
April 27, 2015, 04:59 |
#5 | |
shahrooz
Rep Power: 14 |
under relaxation factors are in a part where coefficients are calculated. after calculating aP look for a line like this aP = aP / urfm or ap = aP / alpham then go change the amount of urf, alpha or whatever it is named in your solver to a lower amount. |
April 28, 2015, 03:44 |
#6 | |
garry
Rep Power: 12 |
Thank you for your reminding! |
April 28, 2015, 03:53 |
shahrooz
Rep Power: 14 |
I hope you get it to work this way, good luck and you are welcome.
May 20, 2015, 04:32 |
In explicit schemes, CFL number is usually the criterion for stability. It should be lesser than one. If you can not find it really, then have a finer mesh and/or a smaller time step. That will do.
What CFD Program should I use? | frownless | Main CFD Forum | 5 | June 17, 2013 03:09 |
Why I cant use both CFD program at the same time? | brksnn | Main CFD Forum | 0 | February 1, 2013 09:05 |
could someone proose a cfd program for tha above problem | kordou | Main CFD Forum | 0 | September 3, 2009 13:57 |
Select CFD program. | Magnus Kalling | Main CFD Forum | 3 | March 10, 2003 16:42 |
What is the Better Way to Do CFD? | John C. Chien | Main CFD Forum | 54 | April 23, 2001 08:10 |
