STRUCTURE OF CFD CODE
Old   July 27, 2008, 15:20
Default STRUCTURE OF CFD CODE
MAB
Hi i am trying to visualize structure of CFD code. the point where i get stuck is 'how these commercial codes solve the matrix of discritised equations'. the only methods i know are GUASS SEIDEL and SOR etc... but i trying to understand what methods are being used by e.g CFX, FLUENT, PHOENICS etc thanks in advance
Old   July 28, 2008, 01:06
Default Re: STRUCTURE OF CFD CODE
Nabi
They use usually Multigrid. Fluent uses AMG (Algebraic Multigrid). Numeca uses Multigrid. Flow3D 8.0 uses SOR, but they improved their solver to GEMRES is version 9.0. But in anycase they use usually AMG for the new commercial solvers.
Old   July 28, 2008, 04:38
MAB
Thanks Nabi... what about CFX ?
Old   July 28, 2008, 11:52
Charles
Some codes also use conjugate gradient type of solvers.
Old   July 29, 2008, 10:43
jojojo
But note that CG is not a general purpose solver! Those codes might use it for diffusion only cases.
Old   August 10, 2008, 03:47
Anishtain4
not only diffusion BICG or CGSTAB can be implied for a non symetric and even non positive definition matrices but they both break down in some cases as it happened for me. and not to mention lots of codes use a ADI method specially for a 3d code. I prefer it while you can use it because of simplisity and efficiency.
Structure of CFD code Shyam Main CFD Forum 5 April 26, 2006 12:04
ASME CFD Symposium Chris Kleijn Main CFD Forum 0 August 22, 2001 06:41
user friendly cfd code waqar Main CFD Forum 19 August 18, 2000 16:31
cfd job Dr. Don I anyanwu Main CFD Forum 20 May 17, 1999 15:13
Commercial CFD code Hanson G. He Main CFD Forum 1 October 15, 1998 08:49
