Appropriate Numerical Scheme
Old   August 22, 2008, 11:45
Default Appropriate Numerical Scheme
Dr N M Sudharsan
I am trying to write a code and would like to know what would be the appropriate numerical scheme to capture the flow from Supersonic to Subsonic. We are looking at Mach 3 to subsonic and a mixed external as well as internal flow. Dr N M Sudharsan
Old   August 23, 2008, 06:26
Default Re: Appropriate Numerical Scheme
Ahmed
There is a wide range of length and time scales involved in the range of speeds that you are proposing to your program. A pressure coupled solver will do well in the transonic to supersonic speeds, but what about the incompressible range You would need a SIMPLE type solver I do not think you can cover the whole range with a single scheme, check the commercial solvers available, FLUENT and like, they provide different schemes Good Luck
Numerical viscosity due to the MUSCL and HLL coulpled scheme sonsiest Main CFD Forum 0 May 23, 2011 15:37
problem about numerical scheme in LES. libin Main CFD Forum 4 July 1, 2004 04:32
The numerical scheme in LES? Martin Main CFD Forum 1 May 24, 2004 04:49
the numerical scheme for LES. John S Main CFD Forum 2 March 14, 2004 07:52
numerical scheme ado Main CFD Forum 3 October 12, 2000 08:20
