August 24, 2008, 18:01 |
flow with high turbulent viscosity ratio
I am just wondering what kind of flow would you expect to have high turbulent viscosity ratio, is it flow with high swirl, high Re, high temperature or other conditions??
Please give me some advise, thanks |
August 25, 2008, 16:45 |
Re: flow with high turbulent viscosity ratio
Any flow with high turbulent viscosity.
August 25, 2008, 18:01 |
1- Write down the definition of turbulent viscosity ratio
(check the wiki) 2- what variables need to be changed in order to get what you consider high turbulent viscosity ratio. You need to tell us what values are considered high 3- how would you classify the flows with these assumed changes. 4- write an article, have it available on the wiki, and we all will thank you for that. |
turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 511831 cells | ZQWY | FLUENT | 18 | June 8, 2023 11:36 |
turbulent viscosity limited to viscosity ratio | Elizabeth | FLUENT | 13 | December 16, 2014 08:57 |
pressure eq. "converges" after few time steps | maddalena | OpenFOAM Running, Solving & CFD | 69 | July 21, 2011 07:42 |
High viscosity flow | robert | Main CFD Forum | 0 | September 10, 2002 09:43 |
Problem of Turbulent Viscosity Ratio Limited | David Yang | FLUENT | 3 | June 3, 2002 06:13 |
