Code for most powerfull FDV Method
Old   August 16, 2008, 09:32
Default Code for most powerfull FDV Method
D.S.Nasan
Dear Sir / Madam/Friends
SUBEVELOPING SCIENTIFIC ALGORITHMS FOR THE MOST POWERFUL COMMERCIAL UNIFIED CFD METHOD ENGINEERING SOFTWARE PACKAGE BASED ON THERMO-FLUID FLOW FIELD DEPENDENT VARIATION (FDV) THEORY.
. During my M.Tech (Thermal Engineering) course, I have carried out project work titled " Grand Unification of CFD methods to Resolve and Characterize Multi-complex Physical phenomena in Thermo-Fluid Dynamics". This project work was primarily focused on the very special and powerful FLOW FIELD DEPENDENT VARIATION (FDV) method .Most of the currently available computational schemes in finite difference method (FDM), finite element method(FEM) and finite volume method(FVM)can be generated as special cases of FDV method for computational solution to every thermo-fluid flow physical phenomena.
I have have keen interest to be a part of R & D team of an organization for developing scientific algorithms for commercial Unified CFD method engineering software package based on FDV theory. With the arrival of such commercial Unified CFD method engineering software package based on FDV theory, does the existing commercial CFD Software engineering package/tools like FLUENT, CFX, ANSA, STAR â€" CD, ICEM â€"CFD, TGRID, PROSTAR will face stiff resistance in the commercial market ? This depends on upon how extensively and rigorously future research on Unified CFD method via FDV theory is carried out . I want to know is there any organization whose R & D activities is shifted toward Unified CFD method via FDV theory for enhancing their future business by developing most Power full Commercial Unified CFD Method Engineering Software package.
. In this regard, presently I am making earnest efforts to contact reputed organizations involved in developing / utilizing existing commercial CFD Software engineering package/tools to present the superiority of FDV method over the current prominent CFD methods/ schemes. Till yet there no response.
So I want know the right platform where I can present my idea of developing such a power full commercial unifiedCFD package so as have commercial benefits or a prospect employment
Thanking you,
With Warm regards
D.S.Nasan
Old   August 16, 2008, 11:50
Default Re: Code for most powerfull FDV Method
Pauli
That's a whole bunch of hype your peddling. Do you have any data to back up those claims?
Old   August 16, 2008, 19:34
TG
Are you also planning on feeding the entire world, creating world peace and solving global warming too?
Old   August 16, 2008, 23:49
Ahmed
any papers/articles/links to read about this method
Old   August 19, 2008, 08:51
D.S.Nasan
Dear Ahmed,
Here some of the references on FDV(Flow field Dependent variation ) Method.
Schunk, Canabal, Fransisco, Chung, Heard, Gary & Grey (1999) 'Unified CFD methods via flow field â€" dependent variation theory' AIAA paper, 99-3715.
Garcia & Chung (1997) 'Flow field-dependent mixed explicit-implicit algorithm for Computational Fluid Dynamics' PP:1-20 Research program (NASA-CR-205035) Langley Research Center, NASA
Chung (1999) 'Transitions and interactions of invicid/viscous, compressible/incompressible and laminar/turbulent flows', International Journal for Numerical Methods in Fluids 31,273-46.
Moon, Yoon & Chung (1996) 'Numerical simulation of Heat Transfer in Chemically Reactive Shock Wave Turbulent Boundary Layer Interaction' Numerical Heat Transfer, Vol: 30, Part A, PP 55-72
Yoon, Moon, Garcia, Heard, Chung (1998) 'Flow field â€" dependent mixed â€"Implicit methods for High and Low speed and compressible and incompressible flows' Computer methods in Applied Mechanics and Engineering 151, 75-104.
Yoon & Chung (1996) 'Three Dimensional Mixed Explicit-Implicit Galerkin Spectral Element methods for High Speed Turbulent Compressible Flows' Computer methods in Mechanics and Engineering, Vol: 135, PP: 343-367
Roy, Frolov, Chung & Givi (1997) 'A new computational approach with flow field dependent variation algorithm for applications to Supersonic Combustion' Advanced Computation And Analysis of Combustion. Moscow: ENAS Publishers, 466-89
Schunk, Richard Gregory, Chung (2001) 'Parallization of Flow field dependent variation Scheme for solving the Triple Shock Boundary layer interaction problem' Accessible Source: NASA Technical Reports Server
Richard son, Karr, Chung, Pendleton (2000) 'Flow field dependent variation method for complex relativistic fluids', American Institute of Physics(AIP )Conference proceedings- Vol. 526,PP 494- 498
Richard Son, Chung (2002) ' Computational relativistic Astrophysics using the Flow field dependent variation theory' Astrophysics journal Accessible Source: NASA Technical Reports Server
Chung, 'Computational Fluid Dynamics', Cambridge University Press 2002.
Thanking You,
With regards
D.S Nasan
Old   August 19, 2008, 20:21
Ahmed
Thanks for the information. I will refer to the last one in your list, the book by Chung, as readers of this forum can go through it using the google book shelf. As you see, the FDV is a unified approach to develop discretised formulas for the Finite difference method, as you might well know, the FDM is used in some specialised codes, but not in general purpose codes which are following the FV method. Why? 1- You have to deal with real world geometries not idealized academic problems. 2- You have to preserve the physics of the problem. 3- easy to code (less bugs) Your enthusiasm is well appreciated, but you need to get closer to real world situations. Good luck and keep up your enthusiasm
Old   September 4, 2008, 02:08
C.T.
Actually, if you take a closer look at Chung's book, you will find that the FDV method is an expression of the Navier Stokes equations that is applicable to finite difference, finite element, or finite volume discretizations. The FDV finite difference formulation is described in section 6.5. However, the finite volume via finite difference formulation is in section 7.4, the finite element formulation is in section 13.6, and the finite volume via finite element formulation is in section 15.2.2(4). The theory looks promising, however I have not look deeply into its validation. If I can find some time (very rare with work and two kids these days), I might look into it further and post some comments here and on clusternut.net.
The FOAM Documentation Project - SHUT-DOWN holger_marschall OpenFOAM 242 March 7, 2013 12:30
Sample SIMPLE method CFD code entitledx Main CFD Forum 8 May 27, 2012 06:22
State of the art in CFD technology Juan Carlos GARCIA SALAS Main CFD Forum 39 November 1, 1999 14:34
public CFD Code development Heinz Wilkening Main CFD Forum 38 March 5, 1999 11:44
What kind of Cmmercial CFD code you feel well? Lans Main CFD Forum 13 October 27, 1998 10:20
