Looking for a benchmark for fluid flow between cylinders
Old   July 16, 2015, 16:29
Default Looking for a benchmark for fluid flow between cylinders
SinaJ
sina_mech is on a distinguished road
Hi
I'm looking for a numerical/experimental/analytical solution for fluid flow between a rotating cylinder with vertical load inside another stationary cylinder (which resembles the fluid motion in journal bearings). I'm looking for a 2D solution for Newtonian fluid.
I appreciate your help
sina_mech is offline   Reply With Quote
Old   July 16, 2015, 17:51
Michael Prinkey
mprinkey will become famous soon enough
If the cylinders are concentric, the solution is very easy. Any grad level fluid dynamics book will have it. I found this in 5 seconds of googling:
http://www.nptel.ac.in/courses/11210...ric_rotate.htm
If the cylinders are NOT concentric, as they are in a loaded bearing, you should look at the Reynolds equation. It is a reduced form of the NS equations (using assumed velocity profiles) and gives you the pressure distribution associated with the offset rotating flow.
mprinkey is offline   Reply With Quote
Old   July 16, 2015, 18:01
SinaJ
Thanks for your reply. The link you provided is for a basic fluid dynamics problem. As I mentioned, I'm looking for a solution that the inner cylinder is under a applied vertical force. Please see the attached photo (sorry for the quality. just took a picture by my phone).
Thanks.
Old   July 16, 2015, 18:10
Michael Prinkey
Then, as I said, read up on Reynolds equation solutions. You can get the pressure field from the Reynolds equations and then back calculate the velocity fields based on the assumed profiles (used to build the Reynolds equation) and the solved pressure field. I don't know that a closed-form solution exists for full incompressible NS for non-concentric rotating cylinders. Maybe there is a perturbation solution that can be constructed using the concentric solution as a base and perturbing it for small values of eccentricity.
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Pressure Outlet Targeted Mass Flow Rate LuckyTran FLUENT 1 November 23, 2016 10:40
Axial Flow between rotating cylinders pavitran CFX 1 February 28, 2015 06:36
Simulating flow for rotating cylinders with a stationary body in the annulus diwakaranant SU2 5 December 10, 2013 05:09
Benchmark problem in two phase flow Ram Dayal CFX 2 August 8, 2006 23:07
