How to judge the velocity boundary layer thick...
Old   September 21, 2008, 03:16
Default How to judge the velocity boundary layer thick...
xumustc
How to judge the velocity boundary layer thickness by numerical code? As well as we know,the definition of velocity boundary layer thickness is given as being at the point where the velocity reaches a certain percentage of the outer velocity , e.g.,99%. Well,in the numerical coding,how to realize that?How we know how many the outer velocity was? The following part ,on how we handle with the puzzle,is to be written, after your advice.
Old   September 21, 2008, 17:19
Default Re: How to judge the velocity boundary layer thick
otd
In my experience, the displacement boundary layer thickness is much easier to calculate. It's just a numerical integration.
You should find a definition in most modern fluids/heat transfer books.
Old   September 23, 2008, 14:45
Harish
A simple rule of thumb for laminar flows is delta ~ 1/sqrt(re). For most laminar flows this is a much more restrictive condition than the exact thickness of boundary layer. You can replace 1 with some constant less than 1 and also check.
Old   September 29, 2008, 02:07
xumustc
Thank you for advice! Indeed the caculation of the displacement boundary layer thickness is much easier than that of the velocity boundary layer thickness.
Old   September 29, 2008, 02:15
xumustc
Thank you for your expert advice! In our practice,we use the following rule of thumb during numerical caculation: (u(n+1)-u(n))/u(n+1)<0.02 (u(n+1)-u(n))/u(n+1)>0.001 u(n+1)-u(n)>1e-8
where u(n) means the velocity at the n-st point on the normal direction to the wall. That's all ,thank you!
Problem with assigned inlet velocity profile as a boundary condition Ozgur_ FLUENT 5 August 25, 2015 04:58
OpenFOAM Variable Velocity Boundary Conditions NickolasPl OpenFOAM Programming & Development 2 May 19, 2011 05:37
Boundary layer profile at inlet for cavity study in fluent uea Main CFD Forum 0 May 14, 2011 13:01
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
Boundary Layer Meshing of a nosecone Chris FLUENT 1 March 15, 2005 12:42
