storing coordinates in array of various blocks with different sizes (structured grid)
Old   August 19, 2015, 06:32
Default storing coordinates in array of various blocks with different sizes (structured grid)
Tom-Robin Teschner
t.teschner is on a distinguished road
hey there,
I am currently developing a structured mesh based solver with curve linear coordinates and hence my mesh is composed of various blocks. I am wondering how to best store the coordinates (in fortran). If the number of points per block in x and y (in 2d) would be the same for all blocks, it would be straight forward and I would have something like coordinateX(nblocks,nx,ny) but what happens if I have blocks of different sizes? I can't declare enough arrays before hand (like coordinateX1, coordinateX2, coordinate X3 ...) as that would limit the number of blocks per mesh, I also don't want to declare the array with the maximum number of points in x and y as I would waste a lot of computer resources. I'd like to stick with fortran for this problem but I know that in C/C++ it would have been a no brainer (but not an option at the moment).
any ideas?
t.teschner is offline   Reply With Quote
Old   August 19, 2015, 12:19
Troy Snyder
tas38 is on a distinguished road
Originally Posted by t.teschner View Post
hey there,
any ideas?
Is there any issue simply making the arrays allocatable? Then you can declare their
size and de-allocate as needed.
An example...
integer,parameter:: prec=selected_real_kind(15,307)
real(kind=prec),dimension(:,:,:),allocatable:: coordinateX
...some code...
allocate( coordinateX(nx,ny,nz) )
...some code making use of coordinateX...
deallocate( coordinateX )
tas38 is offline   Reply With Quote
Old   August 19, 2015, 14:29
Tom-Robin Teschner
no, the problem is that nx, ny and nz are different for each block. you could declare one new array for each block but then you would need to know how many blocks you have in advance which somewhat limits you (as stated before).
but i found a solution that is working for me now which comes from unstructured grids (where i feel more comfortable) by having 3 arrays, i.e. coordinateX, coordinateY and coordinateZ where I store all the x,y and z coordinates of all the blocks. that means that these 3 arrays do not necessarily have the same length. then i have a helper array which states from where to where each block is placed inside the coordinate arrays. for example i could have coordinateX = [ 1 0 0 2 0 0 ] and helper(1,1) = 1, helper(1,2) = 3 and helper(2,1) = 4, helper(2,2) = 6. in this case i have two blocks, the first one goes from element 1 to 3 and the second block goes from 4-6. not the most elegant way i find but maybe someone comes up with a better solution. i just put it here in detail in case someone is coming across the same problem and can live with this fix.
Old   August 19, 2015, 14:40
Troy Snyder
Ok, now I see the issue.
Your solution sounds very similar to the method employed in the Ferziger and Peric
book. Therein all data is stored in 1D arrays with an appropriate indexing function that
incorporates a block identifier, and the i,j,k indices of block of interest. In your case,
the indexing function could simply evolve as the blocks are created rather than be
set a priori.
Old   August 19, 2015, 14:48
Tom-Robin Teschner
yeah, well, if ferziger and peric are using the same approach, I can't be that much off I guess. I got it from the book of Rainald Löhner (applied cfd techniques) but as I said in the context of unstructured grids. But I guess I have to put up with those more cumbersome datastructure
Old   August 20, 2015, 02:53
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
How about using allocatable arrays of derived types in fortran?
Something like this...
TYPE :: positions
    REAL(DP), DIMENSION(3) :: pos
END TYPE positions
TYPE :: points
  TYPE(positions), DIMENSION(:), ALLOCATABLE :: point
END TYPE points
TYPE(points), DIMENSION(:), ALLOCATABLE :: block
flotus1 is offline   Reply With Quote
Old   August 20, 2015, 04:14
Tom-Robin Teschner
I was not aware of derived types in fortran. Will do some reading up and see if I can use this structure, thanks
Mesh Conversion : structured to unstructured shreyasr ANSYS 8 April 8, 2019 07:03
[OpenFOAM] View grid coordinates in Paraview ozzythewise ParaView 3 June 6, 2017 04:12
convert a structured multiblock grid to an one unstructured: modification of cells Mirage ANSYS 0 July 18, 2012 09:14
Grid Independent Solution Chuck Leakeas Main CFD Forum 2 May 26, 2000 11:18
Grid generator for structured grids Tore Myhrvold Main CFD Forum 5 January 21, 1999 08:09
