Conservation of kinetic energy
Like Tree3Likes
  • 1 Post By Simbelmynė
  • 1 Post By LuckyTran
  • 1 Post By FMDenaro
Old   August 28, 2015, 10:33
Default Conservation of kinetic energy
Simbelmynė's Avatar
Simbelmynė is on a distinguished road
Hey,
I am doing a kinetic energy conservation test for my colocated code and have a question regarding the setup.
Mesh: 33x33
I use periodic boundary conditions with a Taylor vortex initial condition.
The kinetic energy is dissipated if the initial velocities are too high, but if I make sure that they are low then there is no dissipation of kinetic energy.
What may be the cause of this? (some Peclét number violation?)
utkunun likes this.
Simbelmynė is offline   Reply With Quote
Old   August 28, 2015, 11:18
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by Simbelmynė View Post
Hey,
Mesh: 33x33
The conservation of kinetic energy is a constraint valid in the inviscid limit, thus no other Peclet number than infinity you have ...
Running the Euler equations does not mean you have no numerical viscosity in your method, therefore the magnitude of dissipation can depend on the mesh size.
Please, give more details of what you are doing
FMDenaro is online now   Reply With Quote
Old   August 28, 2015, 11:54
Simbelmynė's Avatar
Of course you are correct about the Peclét number!
I have a coarse 2d grid and I prescribe periodic boundary conditions and an initial Taylor vortex field. I set the viscosity to zero and use CD for the convective derivatives. Time-stepping is a simple explicit Euler (so very small time-steps are used).
I notice that the magnitude of the initial field have an impact on the kinetic energy conservation of the method. I have not tested finer grids, but the kinetic conservation properties are very good for small values of the initial field (k/k0 less than 1e-7 for a 1 second simulation).
Old   August 28, 2015, 12:05
but the FTCS scheme is unconditionally unstable in the inviscid problem!!
Old   August 28, 2015, 12:06
Lucky
This sounds like numerical diffusion.
Setting viscosity to 0 will eliminate physical/molecular diffusion but you will still have numerical diffusion. Numerical diffusion is hard to limit for these types of problems even with a fine grid, since in Fluent you are limited to a few discretization schemes (2nd order in time, and 2nd upwind or central in space). To control numerical diffusion better, you need either a really fine grid able to resolve all the gradients or use a higher order scheme (4th order, etc).
Old   August 28, 2015, 12:12
Simbelmynė's Avatar
OK, so I just ran a 1000 seconds simulation to test the stability. Works fine. The kinetic energy is growing slowly and end up with 1.3% difference (I was forced to use a time-step that is two orders of magnitude larger than what I would like to use, but for this test I think it is sufficient).
Old   August 28, 2015, 12:14
but there is no meaning in testing an unstable method ......
Simbelmynė's Avatar
I have a 4th order CD implemented as well, but I have not compared the results directly to the 2nd order CD. However, it is very clear that the impact is far less than if I modify the magnitude of the initial field.
Old   August 28, 2015, 12:22
Simbelmynė's Avatar
So you mean that this might be the cause of my observations? I just ran the same simulation with Upwind and the kinetic energy is dissipated a lot (although it is decreasing now instead of increasing).
Old   August 28, 2015, 12:25
upwind is stable (c<1) and is ok testing it, but I don't see correct using any unstable method even for few time steps (actually, it is useful but for students that experiment what the numerical instability is)
Old   August 28, 2015, 12:32
Lucky
I am not familiar with how you are characterizing the rate of dissipation of kinetic energy. Are we talking about numerical diffusion or something else?
But, numerical diffusion is proportional to the gradients. With higher initial velocity, the gradients are greater and this would obviously result in "more" numerical diffusion. If you want to see the same result with higher velocity, you would need to increase the size of your domain so that the new combination of the velocity and length scale result in the same velocity gradient.
The 1st order upwind scheme is infamously high in numerical diffusion (which also improves stability) so that is no surprise. The FTCS scheme is unstable w/o numerical diffusion, the presence of numerical diffusion can make it stable. The fact that your solution was not unstable after 1000 s is basically proof that there is numerical diffusion in your problem setup.
Simbelmynė likes this.
Old   August 28, 2015, 12:33
Simbelmynė's Avatar
Yes, well the simulation did not blow up with the CD even though I took 1e6 time-steps and it produces results that are much better compared to the upwind case.
A blend between UD and CD produces approx 8% decrease in kinetic energy after 1000 seconds @ dt=1e-3.
A CD produces approx 1% increase in kinetic energy for the same case (a 4th order CD slightly less).
Old   August 28, 2015, 12:37
Simbelmynė's Avatar
I am taking the total kinetic energy in the domain, k, divided by the initial total kinetic energy in the domain, k0.
Perhaps I go about this problem in the wrong way. How would you suggest to test the kinetic energy conservation properties of a method. Any other suggestions would be most welcome.
Old   August 28, 2015, 12:42
the numerical instability is a process that can be slow, especially if you used a very low time step....
Your test setting with Taylor is good, you have simply to use stable schemes and checking the integral of the kinetic energy in time with the same initial condition but for refined grids.
Old   August 28, 2015, 13:01
Simbelmynė's Avatar
OK, I just ran a 65x65 (up from the 33x33) and there is a sizable improvement in the Upwind solution. What constitutes as a good solution? I have a paper that claims the Rhie-Chow interpolation method produces poor solutions in terms of kinetic energy conservation. However, their test case is for 1 second and it shows that Rhie-Chow dissipates less than 0.03% in that time-span. In what situations will this be a problem (long simulations using LES?)?
Old   August 28, 2015, 13:12
you could check further test-cases as I did in Int. J. Numer. Meth. Fluids 2007; 53:1127–1172.
the LES equation provided a velocity field that is no longer v(x,t) but v_f(x,t). The equation for the energy field v_f.v_f shows that such quantity is no longer conserved
How to exploit SGS kinetic energy with Smagorinsky model in LES babakflame OpenFOAM Programming & Development 3 December 14, 2014 06:58
A question about filtered kinetic energy 8cold8hot Main CFD Forum 0 November 2, 2014 01:56
How to view subgrid kinetic energy Craig FLUENT 3 September 8, 2012 11:34
Kinetic Energy Conservation longamon OpenFOAM Running, Solving & CFD 1 May 28, 2011 02:08
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
