Hi all,
I'm having trouble with the reinitialization procedure of the level set method. I'm solving phi_t + S(phi_0)*(|grad phi| - 1) = 0 using 5th order WENO and RK TVD scheme to steady state. My problem is that my resulting level set function has small oscillations on it, which corrupt the computation of the curvature field after a few iterations. Does anyone know where these oscillations may come from? Thanks in advance. greets uter |
why u do not use validated opensource library in this regard
look at this: http://ktchu.serendipityresearch.org...lib/index.html |
Freedom
Rep Power: 13 ![]() |
Do you know how to implement this library into OF? Could you give us some hints?
Reinitialization for Level set method | Amir | Main CFD Forum | 1 | July 7, 2009 06:41 |
using level set method | rubby | Main CFD Forum | 2 | March 7, 2009 02:02 |
Level set & distance functions | Renato. | Main CFD Forum | 7 | February 7, 2006 06:46 |
initialize level set | ls newbie | Main CFD Forum | 0 | March 17, 2004 14:17 |
Level Set in Cavitation Modeling | Niklas Wikstrom | Main CFD Forum | 1 | September 9, 1999 13:08 |
