ABAQUS CFD Fluid-Structure-CoSimulation
Like Tree1Likes
  • 1 Post By TU_61
Old   September 1, 2015, 10:55
Default ABAQUS CFD Fluid-Structure-CoSimulation
TU_61 is on a distinguished road
I am doing a Co-Simulation in ABAQUS 6.14, where a fluid (water) flows through a Solid Steel. In my first trials, I used a Solid with one consistent hole, and a fluid. Everything worked perfect.
In my second trial the solid is wider and with two holes, so the fluid flows in one hole in and comes out at the other hole.
Step : Dynamic, implicit
I canīt start the Calculation, the Calculation gets aborted everytime and for the fluid the Error Message appears: Analysis cannot continue due to Co-Simulation Engine mapping search failures. Normally it could be the error message that two co-boundary of the fluid and solid do not match, but I checked everything.
I really do not have a clue why it does not work when I model i with an In-and Outlet on the same side. As an Attachment I put the image of the two bodies for a better understanding.
Thanks !
alibayari.optl likes this.
TU_61 is offline   Reply With Quote
Old   March 15, 2018, 23:49
NabF
nabF is on a distinguished road
Did you found the solution of this error?I am encountering the same one.
nabF is offline   Reply With Quote
abaqus, fsi
chosing Abaqus cfd? dennyg Main CFD Forum 0 August 24, 2013 21:38
Fluid Structure interaction prince_pahariaa FLUENT 3 March 19, 2013 12:16
microfluid fluid structure interacion problem sorrego CFX 0 July 2, 2012 15:16
Can we quantify the fruits of CFD? Brady Brown Main CFD Forum 14 December 15, 1999 09:42
ASME CFD Symposium - Call for Papers Chris R. Kleijn Main CFD Forum 0 September 3, 1998 08:45
