How to set LES simulation, what one should know?
Old   December 8, 2014, 11:38
Question How to set LES simulation, what one should know?
Danijela Djuric Mijovic
danijela.djuric.mijovic is on a distinguished road
Hallo everybody,
Until now I dealed with RANS only considering wind flow in an empty domain and getting the pressure coeff on the facade walls. I manage it after a lot of learning.
Now I need to find out maximum and minimum pressures on the same walls. Is it too complicated? What I should know? Where I can find it?
When I tried I was confused with the following: total time, time step and initial time? I don't have a hint what values should be there.
Thank You people!
danijela.djuric.mijovic is offline   Reply With Quote
Old   December 8, 2014, 11:52
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by danijela.djuric.mijovic View Post
Hallo everybody,
Thank You people!
The problem solved with LES is not only depending on the good mesh resolution and proper time step, but you need to face a real time-dependent case which is really different from RANS. Thus, you need to wait until the numerical transient is finished, then sampling the fields to perform statistical analysis
FMDenaro is offline   Reply With Quote
Old   December 8, 2014, 11:59
Thnx for quick reply. Any paper, literature?
Old   December 8, 2014, 12:11
the book of Sagaut
Old   December 9, 2014, 16:04
Thank You! i will try... not much time
correction of Grub after installing Windows XP and 8 immortality Lounge 20 January 5, 2014 17:41
How to conduct transient LES simulation tianrenshui311 FLUENT 0 November 15, 2010 13:21
how to set electric permittivity in plasma actuator induce flow simulation. mukut Phoenics 3 November 1, 2010 21:50
How to show the transient case? H.P.LIU Phoenics 7 July 13, 2010 04:31
LES simulation of vibrating Wing gtg627e OpenFOAM Running, Solving & CFD 0 September 6, 2007 01:36
