Pressure solver in Matlab using the code developed by Benjamin Seibold
Old   September 26, 2015, 02:42
Question Pressure solver in Matlab using the code developed by Benjamin Seibold
Mehdi
mahdi_kh8 is on a distinguished road
Send a message via Yahoo to mahdi_kh8
I am trying to check different pressure solvers and have better understanding.
Interestingly, when I replace codes I do not get correct results.
Original code for pressure:
    Lp = kron(speye(ny),K1(nx,hx,1))+kron(K1(ny,hy,1),speye(nx));
    Lp(1,1) = 3/2*Lp(1,1);
    perp = symamd(Lp); Rp = chol(Lp(perp,perp)); Rpt = Rp';
    rhs = reshape(diff([uW;U;uE])/hx+diff([vS' V vN']')'/hy,[],1);
    p(perp) = -Rp\(Rpt\rhs(perp));
    P = reshape(p,nx,ny);
Edited code:
    % p(perp) = -Rp\(Rpt\rhs(perp));
    p= Lp\rhs;
or
    [p,flagCG,relresCG,iterCG,rCG] = pcg(Lp,rhs,1e-06,10000);
None of the above changes work.
What is missing here?
Any advise would be appreciated.
Cheers,
mahdi_kh8 is offline   Reply With Quote
Old   September 26, 2015, 03:33
Smile Answer:
Mehdi
There was a small mistake:
    P=-P;
matlab coding, pressure solver
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 06:40
static vs. total pressure auf dem feld FLUENT 17 February 26, 2016 13:04
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC Endel OpenFOAM Running, Solving & CFD 3 September 11, 2014 16:29
The correction on pressure equation of SIMPLE algorithm in MRFSimpleFOAM solver renyun0511 OpenFOAM Running, Solving & CFD 0 November 10, 2010 01:47
Reading forces within solver code SD@TUB OpenFOAM Running, Solving & CFD 0 February 28, 2010 18:39
