September 29, 2015, 09:54 |
rotating control point
Ava
Rep Power: 12 |
Hi everybody,
I am working on a vertical axis wind turbine and I wish to export data in a couple of regions adjacent to the blades. Since, I am using a moving zone (mesh), I can not simply generate a line/rake as their location does not update as the blades move. How can I do this? Thank you very much in advance, |
September 30, 2015, 05:22 |
Kaya Onur Dag
Rep Power: 13 |
Can't your solver interpolate the data-you-want at a given 'position'?
If so, you know the rotation speed of the wind turbine, update your 'position' and extract the interpolated data at each time step. Your hands are tied with interpolations since you can't be sure that there is a mesh point at the point you want your data to be extracted. If you solver doesn't provide such, extract the whole domain with mesh point coordinates at every time step and interpolate yourself. Last edited by kaya; September 30, 2015 at 12:34. |
Radiation Modeling | Chris89 | CFX | 20 | August 14, 2014 07:51 |
Floating point exception error [High rotating speed tube] | wkwong | STAR-CCM+ | 9 | February 14, 2014 13:09 |
FSI: Pressure and Normal Force don't match with expected values | Geraud | CFX | 6 | August 21, 2012 15:34 |
transient simulation of a rotating rectangle | icesniffer | CFX | 1 | August 8, 2009 07:25 |
monitoring point of total temperature | rogbrito | FLUENT | 0 | June 21, 2009 17:31 |
