Flow Simulation : air around an rotating cylinder using Solidworks Flow Simulation
Old   October 22, 2015, 08:48
Question Flow Simulation : air around an rotating cylinder using Solidworks Flow Simulation
Rémi
Wyrold is on a distinguished road
I’m a student in High school and i’m working on a project of an aeromodelism aircraft lifted by wings working with the “Magnus effect” : Cylinder wings rotating around themselves, the Magnus effect would product a lift (see : http://goo.gl/XiDVa8).
I’ve decided to highlight the Magnus effect and to deduct a difference of pression that will be used to establish the lift effort using Solidworks Flow Simulation.
After many tries, impossible to obtain a good result.To begin, i’ve just represented the wing as a cylinder to simplify the calculations as far as I could. Then, I followed this method : https://goo.gl/26AMsr, which consists to simulate the piece’s rotation by a cylinder which contains it.
First, I met the following issue : impossible to do the calculations with the software, the piece in rotation was the same as the cylinder created in order to simulate the rotation. An error was popping up to the screen without any results.
By modifying the diameter of the piece, I could obtain results but they were unlikely.
That's why I am turning towards you, I hope I had been clear enough, if you need any other informations, ask me.
Thank you for your help.
Wyrold is offline   Reply With Quote
air flow impinge on a hot cylinder dbnrop OpenFOAM Running, Solving & CFD 1 April 28, 2014 09:30
Differences and functions of Solidworks Simulation and Solidworks Flow Simulation? alpharays Main CFD Forum 0 April 19, 2012 03:13
transient simulation of a rotating rectangle icesniffer CFX 1 August 8, 2009 07:25
Air flow over a cylinder - what regime? momentum_waves Main CFD Forum 6 November 19, 2008 12:08
Air flow over a cylinder momentum_waves Main CFD Forum 1 November 17, 2008 20:54
