convergence Vs under relaxation-2phase flow-2dpipe |
October 25, 2015, 07:23 |
TPRPR1
Rep Power: 13 |
hello all.
I need an explanation for the following. I tried a small 2 phase problem with a small 2d pipe. 8000 hexa elements-very good quality. air-water mixture inlet. turbulent flow 1.Used water at inlet and iterated till convergence was achieved at 10^-7 residual criteria. 2.used 1 as initial condition and introduced air at inlet. The iteration ran for ages and the residuals never reached 10^-3. 3.I drastically reduced the relaxation factors to the order 10^-3. 4.The solution stabilized and achieved convergence at 10^-6(all residuals). Could this be a false convergence result? I am aware one should reduce residuals slowly from 0.8,0.7 and so on; however i reduced it to 10^-3 just to see what happens. I am unable to explain why it achieved convergence in just a few hundred iterations. |
October 25, 2015, 12:13 |
Lucky
Rep Power: 66 |
Is your 2d pipe axisymmetric? Axissymmetric 2d simulations sometimes have a problem with stability and need a little help from slightly smaller urf's than a non-axissymmetric case.
You can always make your residuals arbitrarily small (down to machine precision) by reducing your urf's to ridiculously small residuals. But residuals don't tell you anything about convergence and accuracy. For that you need to be checking solution values. To see if your simulation is converged try changing the urf's back to the original values. You will find that your solution behaves as before and does not stay at the lower levels. What's really important for two-phase flows is an accurate calculation of the interface. With only water you can achieve 10^-7 in residuals because there's no interface. When you introduce air, there's now an interface that numerically oscillations (because of numerical instabilities or whatever) and that makes it very hard to achieve small residuals. You also need a sharp and well-resolved interface to improve your accuracy. |
October 25, 2015, 14:47 |
TPRPR1
Rep Power: 13 |
Thanks for the response. And yes the solution is stable with the small residuals however if I choose default urf's the residual go around 10^-3 and oscillate . In other words would this solution be safe to use or should I start over through a different approach ?
October 25, 2015, 14:50 |
TPRPR1
Rep Power: 13 |
I have some experience with external single phase flows but I'm currently not sure how to validate my results . I would not be able to identify a good resolution of the interface from the bad one .
October 25, 2015, 22:04 |
#5 | |
Lucky
Rep Power: 66 |
I would never trust the result of anyone that used anything but the default urf's. I'm willing to accept factors of 1/2, or 1/4 but not factors of 1/1000.
Residuals do not give information about convergence unless they oscillate around a fixed value which just means that your solution is grid saturated and you need a better grid, i.e. a finer grid to resolve more features of the problem or higher quality grid to reduce numerical oscillations. Quote:
“The first principle is that you must not fool yourself and you are the easiest person to fool.” ― Richard Feynman |
2 phase flow |
Lets talk about relaxation factor optimization | chriss85 | OpenFOAM Running, Solving & CFD | 35 | June 21, 2019 09:54 |
Convergence with reduced under relaxation and time scale factors | saisanthoshm88 | CFX | 3 | March 20, 2013 06:04 |
Convergence with reduced under relaxation and time scale factors | saisanthoshm88 | FLUENT | 0 | March 19, 2013 10:08 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
Relaxation and convergence | sammi | Phoenics | 0 | March 20, 2008 03:32 |
