Does artifical dissipation term makes scheme inconsistent? |
October 31, 2015, 10:41 |
Shainath
Rep Power: 15 |
Central schemes like JST uses artificial dissipation for the stabilization. This modification is an artificial one. Does this additional term makes system inconsistent? Can we expect this term to be zero at the end of the simulation? This is in reference with incompressible flow schemes. In the following references they have used the pressure differences as a dissipation to continuity equations. Is it must to reach these terms to zero at the end of the simulation (steady)?
Reference 1(Link: http://heja.szif.hu/ANM/ANM-030110-A/anm030110a.pdf) Reference 2(Link: http://www.sciencedirect.com/science...21999199963155) |
October 31, 2015, 10:59 |
Filippo Maria Denaro
Rep Power: 71 |
the scheme should be consistent in the sense that the numerical dissipation mathematical vanishes as the grid size goes to zero.
Of course, in any numerical simulation that does not happen and you have a "modified equation" |
October 31, 2015, 11:19 |
Shainath
Rep Power: 15 |
Thanks a lot FMDenaro Sir for the answer,
I still have a doubt. In principle for Artificial compressibility method lower values of norms of time derivative terms indicates the satisfaction of divergence of velocity. But in the above cases where artificial dissipation is added to continuity equation which will not go zero at the end of pseudo-transience. Will there also norms of time derivative terms indicates the satisfaction of divergence of velocity? |
October 31, 2015, 11:33 |
#4 | |
Rep Power: 71 |
You should provide some more details about your formulation |
October 31, 2015, 11:36 |
Shainath
Rep Power: 15 |
I am trying the formulation given in reference 2.
Godunov scheme | Peter | Main CFD Forum | 6 | November 27, 2009 10:51 |
Dissipation in Harten-Yee and Davis-Yee TVD Scheme | cfdxue | Main CFD Forum | 0 | April 29, 2008 10:45 |
Dissipation for MacCormack scheme | Jim | Main CFD Forum | 0 | January 26, 2004 14:56 |
artifical dissipation on unstructured meshes | Frederic | Main CFD Forum | 0 | October 31, 2001 17:42 |
TKE SPECTRUM & DISSIPATION | Christian Paukert | Main CFD Forum | 2 | March 14, 2001 19:34 |
