Highest LD ratio designs
Old   January 17, 2011, 09:43
Smile Highest LD ratio designs
Diji N J
dijinj is on a distinguished road
can someone give the technical name or coordinate files of airfoils having highest LD ratio; above 50
also tell me how to generate a sears hack body's coordinate file
dijinj is offline   Reply With Quote
Old   January 19, 2011, 17:03
abdul099 is on a distinguished road
There are a lot of airfoils with a L/D ratio over 50 - as long as you are just looking on the airfoil itself. Even an old one like the E603 will reach a L/D of more than 100, and to be honest, that's an out-of-date airfoil and can't compete with a modern one.
On a real plain, it depends on the aspect ratio of the wing, the shape of the fusselage, the wing tip...
abdul099 is offline   Reply With Quote
Old   January 19, 2011, 21:23
Diji N J
I am looking for wing profile only not complete aircraft. I only need 2d cross section of airfoils
Old   January 19, 2011, 21:29
sail's Avatar
Vieri Abolaffio
sail is on a distinguished road
http://www.worldofkrauss.com/
click on "Search" and look for high L/D airfoils.
sail is offline   Reply With Quote
Old   January 19, 2011, 22:23
Diji N J
Thanks
Thank you very much
coordinate file, ld ratio
diesel spray combustion equivalence ratio usker Siemens 12 March 1, 2008 06:09
High Aspect Ratio elements Flavio CFX 2 November 24, 2006 12:01
stability of scheme due to skewness/aspect ratio zonexo Main CFD Forum 3 May 14, 2006 21:23
On limiting to turbulent viscosity ratio! varghese FLUENT 2 November 15, 2003 08:56
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 06:13
