Vortex shedding frequency stays unaltered
Old   March 4, 2009, 13:04
Default Vortex shedding frequency stays unaltered
Nelson
Hey guys, I'm having problem with the vortex shedding frequency, basically, all I'm doing is increasing the average fluid flow speed from 31.5 (cm/s) to 63 (cm/s), therefore, it's a really low reynolds number.
now I have my timestep of both 0.03 sec, 0.015 and 0.01 sec respectively, and the quality of the result from 0.03 sec isn't really fine, so it's not discussed here, however, my vortex shedding frequency stays 3.7 no matter it's 0.015 sec or 0.03 sec.
At the moment I am comparing the experimental data to the experimental ones, but it doesn't seems to be optimistic, therefore, if there is anyone who can help, it would be deeply appreciated!!!
thank you Nels
Old   March 5, 2009, 06:54
Default Re: Vortex shedding frequency stays unaltered
Julien
What is the Strouhal number you are predicting? How many timesteps do you have per vortex shedding period for the smallest timestep you tested?
Old   March 5, 2009, 09:25
Nels
Hey Julien, thanks for the reply, I am getting 3.7 hz for the 31.5 cm/s which is the same as the literature, however, as velocity doubles, the shedding frequency should doubles, which is the problem, it stays constant as 3.7 Hz.
And the Strouhal number I'm looking for is around 0.1-ish.
for the smallest timestep (i.e: 0.01 sec), I have 23 timesteps per vortex shedding, which shouldn't be the case as I have doubled the free stream velocity setting.
Thanks
Old   March 5, 2009, 10:04
Julien
23 points per period is reasonable. What order accuracy timestepping are you using?
Is there any chance that your code is normalizing out the velocity somewhere?
Other than that, I have no idea.
vortex shedding frequency naveen OpenFOAM 23 May 17, 2016 08:12
frequency of vortex shedding HaKu Main CFD Forum 3 March 18, 2011 00:00
time step and vortex shedding frequency kevin Main CFD Forum 16 November 19, 2009 06:00
Frequency of vortex shedding Giuseppe FLUENT 1 January 10, 2006 08:41
vortex shedding frequency Erdem FLUENT 1 December 30, 2005 18:31
