Valve Cracking Pressure
Old   January 11, 2016, 09:52
Default Valve Cracking Pressure
nicola_78 is on a distinguished road
Hi everybody!
I'd like to evaluate the cracking pressure (which is the minimum upstream pressure to open the valve) of a swing check valve by means of an analytical method and a CFD analysis.
The disc has to open of a small distance.
Any suggestions?
Thanks!!
nicola_78 is offline   Reply With Quote
Old   January 11, 2016, 13:11
Kaya Onur Dag
kaya is on a distinguished road
assuming spring has a constant torque T, and the length between the center of the valve and the spring position is x, so you need flow pressure to generate F = T*x much force on the valve. If the area on the valve is A then you need the static pressure of P > F/A from the flow to open the valve. I don't think you need a cfd computation to find P since the flow is going to be creeping flow at the pressure which is just enogh to open the valve.
I am not sure why you consider CFD for such problem
kaya is offline   Reply With Quote
Old   January 11, 2016, 17:11
First of all T=F*x. Then there is no spring, only the weight of the disc, let's assume it 2kg for example.
It is different, do I have to impose a small angle of rotation (1-2°), just the minimum to make flow pass? Do I have to impose a balance to rotation?
Old   January 11, 2016, 17:27
Kaya Onur Dag
you're right.
to me if there's no spring than any pressure greater than the ambient will make the disk / valve open considering that the center of gravity is aligned with the hinge.
Old   January 12, 2016, 02:33
Unfortunately the solution is different.
cfd, chack, cracking, pressure, valve
static vs. total pressure auf dem feld FLUENT 17 February 26, 2016 13:04
Modelling an initially closed valve which a fluid opens siw CFX 1 April 26, 2014 06:32
how to measure pressure drop through a valve hmasenger CFX 5 April 8, 2013 14:30
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
