High order FINITE VOLUME "upwind" scheme for Convective terms in Momentum equation
Like Tree2Likes
Old   January 2, 2016, 11:05
Default High order FINITE VOLUME "upwind" scheme for Convective terms in Momentum equation
Mihir Makwana
mihirmakwana6 is on a distinguished road
I want to apply a high order say 5th/6th order accurate UPWIND scheme for convective terms ( 2nd term in L.H.S of the momentum equation --- click the link below )
http://i.imgur.com/qDxTpi2.jpg?1
The scheme should be based on FINITE VOLUME METHOD
( as it is applied to momentum equation in conservative form)
Can someone please provide links/name of few research papers
Thanks in Advance.
Cheers !!
mihirmakwana6 is offline   Reply With Quote
Old   January 2, 2016, 11:21
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
I am aware of FV-based fifth order upwind in 1D, however the extension to real multidimensional high order upwind is quite complex...
FMDenaro is offline   Reply With Quote
Old   January 2, 2016, 11:27
Mihir Makwana
I am trying to apply FVM-based high order upwind to convective terms in 3 Dimensions.
Are there any papers on this ??
Old   January 2, 2016, 11:36
Some authors use upwinding in 3D by factorising the problem in each direction and using 1D schemes.
It also depends on the type of flow, if compressible (possibly with shock) or not. If you search with google there are a lot of papers.
Some years ago I worked with high order upwind discretization both 1D and 3D (multidimensional) but only focusing on incompressible flows.
Maybe you can find some useful details.
https://www.researchgate.net/profile...=newest&page=2
Old   January 3, 2016, 04:28
dang son tung
tt_1990 is on a distinguished road
http://www.sciencedirect.com/science...21999104002281.
I hope it's useful to you
tt_1990 is offline   Reply With Quote
Old   January 3, 2016, 05:38
Mihir Makwana
ok Thankyou.
Currently the code is incompressible, but later on I will modify it to Compressible.
However, I will be working in the low mach number regime.
Old   January 3, 2016, 05:39
Mihir Makwana
Originally Posted by tt_1990 View Post
Thankyou. I will have a look at it.
Old   January 3, 2016, 05:46
ok Thankyou.
Ok, so you need only upwinding in the physical space based on the three velocity components.
I think you can find useful details in this paper (specifically based on multidimensional upwind) and its references.
https://www.researchgate.net/publica...mulation_codes
Old   January 3, 2016, 06:41
Mihir Makwana
Sir, the paper uses Collocated grid arrangement whereas I am using staggered grid.
Will the paper still be useful ?
Old   January 3, 2016, 06:50
the general idea of the construction of upwinded region for multidimensional interpolation does not depend upon the type of colocation. However, the implementation will be different.
A higher order scheme for multidimensional upwind would really get you in trouble when using staggered colocation.
Old   January 3, 2016, 18:45
Michael Prinkey
mprinkey will become famous soon enough
There is a great deal of literature in the the 1990s/2000s regarding LES simulations using compact differencing schemes. This is probably one of the most referenced paper. While it is formulated from a finite difference viewpoint, there is an appendix that discusses mid-point interpolation as you would need for a finite volume formulation. And for cartesian methods, Finite Difference and Finite Volume methods are more alike than different.
http://www.math.colostate.edu/~yzhou...le_1992JCP.pdf
As a general note--all of these schemes will lock you into a fully structured Cartesian mesh. Even grid spacing variations are difficult to properly address. And grid transformations must be orthogonal or nearly so to prevent missing higher cross terms from destroying the accuracy. Also, there are no TVD or other smoothness guarantees with these schemes, so you must make sure that your underlying solution is either smooth or that your model has enough artificial damping to keep the wiggles under control near sharp gradients. If you need to properly address discontinuous solutions with high order systems, take a look at WENO schemes. There are versions that are 5th-order or higher.
http://www.enu.kz/repository/2009/AIAA-2009-1612.pdf
If you are concerned with simple Cartesian Control Volume Finite Difference-type formulation, these compact or WENO schemes are useful ways to proceed, in my view. If, however, you need a fully unstructured Finite Volume-type formation that can handle tri/quad/tet/hex meshes, you need to look at Discontinuous Galerkin methods to the exclusion of everything else:
http://www.cfm.brown.edu/people/jans...s/RMMC08-I.pdf
General finite volume methods are very difficult to formulate on unstructured grids. You can see this by just reviewing basic WENO methods formulated for unstructured meshes in 2D and those are not even 5-th order:
http://www3.nd.edu/~yzhang10/RobustWENO.pdf
A great deal of formulation convenience goes away if you are unable to treat interpolation/gradients on an per-axis basis, and this difficulty is ever more amplified as you increase the accuracy order.
Good luck.
mprinkey is offline   Reply With Quote
Old   January 3, 2016, 22:00
Mihir Makwana
Good luck.
Thankyou sir for the reply.
I am using hexahedron C.V ( thus grid lines are along the Cartesian axis ) and the meshing is uniform ( with staggered grid arrangement ) in a particular Cartesian direction.
Also, the solution in the domain is smooth as there are no sharp gradients.
Old   January 4, 2016, 03:37
Hi to all,
while I agree on the difficulty of implementing a code on unstructured grids, let me address some suggestions:
- hybrid FV/FE are best suited on unstructured. That means you can define shape functions in a FE manner but using that for computing any gradient and integral required for a FV method.
- when FV are correctly based on the discretization of the integral form of the equation, you do not get the same algebric system of equation of the FD method, neither on regular structured grid. The difference comes from the discretization of the Div(*) operator in FD methods and in (1/|V|) Int [S] n.() dS in FV methods
Old   January 4, 2016, 09:42
Mihir Makwana
Good luck.
@Michael Prinkey
Sir, the first paper ( Compact finite difference schemes with spectral-like resolution by Sanjiva K. Lele ),
actually uses Central difference schemes.
I am actually looking for UPWIND schemes
Old   January 4, 2016, 13:22
Michael Prinkey
@Michael Prinkey
Also, very common:
http://citeseerx.ist.psu.edu/viewdoc...=rep1&type=pdf
Old   January 5, 2016, 06:48
Mihir Makwana
I found the following paper
http://www.tandfonline.com/doi/pdf/1...07799308955882
See equation 17 where a fifth-order upwind scheme called FOUB scheme is described.
Can I use this scheme for convective terms ?
Old   January 5, 2016, 12:14
at present, I am not able to access to T&F papers
Old   January 5, 2016, 12:45
Mihir Makwana
The paper is
THREE-DIMENSIONAL INCOMPRESSIBLE FLOW CALCULATIONS WITH ALTERNATIVE DISCRETIZATION SCHEMES
by
Panos Tamamidis & Dennis N. Assanis
( I can mail you the paper on your email-id if that is fine with you )
Here is the image where they have mentioned the fifth order upwind scheme
http://i.imgur.com/GlFRysZ.jpg?1
The paper to which they refer i.e Rai[13] is
http://i.imgur.com/Z8cEyLf.jpg?1
to which i don't have access
Old   January 5, 2016, 13:07
Michael Prinkey
The paper is
by
That formula will likely work fine. That is just a midpoint interpolation with three upwind and two downwind samples. The difficulty here will be in implementing boundary conditions--either dropping back to lower order or building lopsided stencils that retain 5th order.
Note too that this form is highly accurate, but it is "not as upwind" as QUICK or other more stable upwinding schemes that make more heavy use of upwind data. So, I suspect that solution stability is going to more tenuous.
Old   January 5, 2016, 13:31
well, I see the eq.(17) and let me comment a couple of issues:
1) the formula is indeed an upwind for the scalar value on a face, however the upwinding on the non linear flux (uu) would be different;
2) the formula is 1D, that means you do not see in it the surface integral that is conversely in effect in 2D and 3D cases. If you use the Eq.(17) as it is, is likely you get simply a second order accuracy in space in an accuracy testing.
Biased and pure upwinding in 1D were analysed in several papers. When I worked on this issue, we analysed the distribution of the errors in physical and spectral space for FD and FV approaches. If you are interested, you can see Section 4 in https://www.researchgate.net/publica...mes_simulation
you will find some "strange" conclusions ...
mprinkey likes this.
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Descretization of momentum equation to solve Navier stokes equation by finite volume manishsathe14 Main CFD Forum 2 December 30, 2012 22:25
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
Finite Volume WENO Scheme DSS Main CFD Forum 3 January 15, 2007 03:47
