January 19, 2005, 04:25 |
Vorticity magnitude
Please could someone tell me how to calculate the vorticity magnitude.
Thanks |
January 19, 2005, 09:04 |
Re: Vorticity magnitude
Compute the curl of velocity and take the magnitude of the vector.
January 20, 2005, 13:21 |
wx = dw/dy - dv/dz wy = du/dz - dw/dx wz = dv/dx - du/dy
w = wx(i) + wy(j) + wz(k) vorticity magnitude = sqrt(w.w) = sqrt( wx*wx +wy*wy +wz*wz) |
January 21, 2005, 21:59 |
Could this function be defined into any cfd post.
August 17, 2011, 10:07 |
or with vorticity tensor
Rep Power: 15 |
|w|=||wij||
where wij is the vorticity tensor defined as the antysymmetric part of the velocity gradient tensor. Its magnitude defined by: ||wij||=sqrt(2wij*wij) and its the same as the magnitude of the vorticity vector as defined earlier. |
March 2, 2016, 00:01 |
#6 | |
Hanxun Yao
Rep Power: 10 |
Hi, If I define a antisymmetric matrix as: 0 x y -x 0 z = A -y -z 0 which is similar to Vorticity tensor, but when I calculate A*A, I got -2*x^2-2*y^2-2*z^2 which is negative and has problem under square root. Could you please tell what causes this problem. Thank you very much. |
March 2, 2016, 03:33 |
#7 | |
Filippo Maria Denaro
Rep Power: 71 |
I do not understand what you did ... if you want to define a measure for a matrix, you should define some norm on that ||A||, this is not so simple. You can define an induced norm by using a (non vanishing) vector x such that ||A.x||/||x|| |
March 2, 2016, 06:04 |
#8 | |
Hanxun Yao
Rep Power: 10 |
Thank you for your reply, Now I know what is the norm of a matrix, then I still have a question: What is the magnitude of vorticity, seems like it is not equal to the norm of vorticity tensor. thanks again. |
March 2, 2016, 06:11 |
#9 | |
Rep Power: 71 |
Indeed the vorticity vector must be extractet from the antisymmetric matrix.. |
October 8, 2021, 01:49 |
Vorticity magnitude in Fluent
#10 |
Shuvam Mohanty
Rep Power: 6 |
By definition, vorticity is a pseudovector field that describes the local spinning motion of a continuum near some point (the tendency of something to rotate. In FLUENT is given by: dY-Velocity/dx minus dX-Velocity/dy.
To plot contours for this function using FLUENT go to the "Define" menu, pick "Custom Field Function". Then in the "Field Functions" drop-down box, pick "Derivatives", select "dY-Velocity/dx" from the second drop-down box, click "Select", then the "-" button, then select "dX-Velocity/dy " and click "Select". Now choose a name for your new variable ("Vorticity-magnitude"), then click "Define". When you go to plot contours, choose "custom field function" and then your variable will pop up there. |
October 8, 2021, 03:42 |
#11 |
Lucky
Rep Power: 66 |
I don't know why someone decided to necrobump this thread but if we're talking about Fluent...
Fluent already has a built-in field for vorticity (going back for as long as I can remember). You don't need to do all this custom field functions business. It's readily available. Just click it :4head: |
Vorticity magnitude | makaero | FLUENT | 0 | May 25, 2011 20:30 |
vorticity boundary condition | bearcharge | Main CFD Forum | 0 | May 14, 2010 11:32 |
magnitude of vorticity using fluent | ryan | Main CFD Forum | 1 | November 30, 2009 16:29 |
Could vorticity magnitude be ploted ? | w0er | Main CFD Forum | 4 | February 8, 2005 07:49 |
Vorticity magnitude | Hernani | Siemens | 2 | August 20, 2001 09:48 |
