Momentum coefficient of airfoil flow
Old   October 23, 2000, 02:37
Default Momentum coefficient of airfoil flow
Marat Hoshim
Hi all,
studying some papers about the calculation of airfoil flow I have got the impression that standard k-eps model with wall function is not suitable at all for that case. Especially when it comes near the stall angle. Even low-re versions of k-eps model do not give accurate results because separation on the suction side is surpressed often. Could someone tell if my impressions concerning that topic are rigth ? Improvement was shown by using k-w models because separation is better captured. Could one also expect improvement when using k-w model with wall functions ? In papers the improvement is mostly shown on the values of cd and ca. Does someone know if I can expect the same improvement for the momentum coeficient ?
Any comment on that are appreciated !
Marat
Old   October 23, 2000, 12:31
Default Re: Momentum coefficient of airfoil flow
sylvain
You're right, RANS models often fail to predict the stall angle.
The Wilkox's k-omega model seems to give better prediction in some case as other model like the Spalart-Almars's one equation model. I think there was an Ercoftac Workshop one or two days ago, organized by TUdelft, where one of the test case was an Aerospatial-A airofoil at 13.3 degre. At this angle a recirculating flow appears on the suction surface and most of the usual turbulent models don't predict it.
I'm not sure that the k-omega turbulence model was design to be used with wall function.
Sylvain
Old   February 8, 2016, 16:53
Default momentum coefficient
arman
armanpournasiri is on a distinguished road
Hi
Is the momentum coefficient with power coefficient to calculate the relationship?How can be calculated.
please help me...
thank you.
armanpournasiri is offline   Reply With Quote
Simulating flow past airfoil with different AOA ramin FLUENT 4 April 22, 2015 13:09
Lift and drag coefficient with strange values for NACA airfoil antonio_ing OpenFOAM Running, Solving & CFD 16 September 13, 2012 12:21
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 06:24
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Simulation of transonic flow over NACA0012 airfoil MSc Student Siemens 2 August 9, 2006 13:49
