April 15, 2016, 13:23 |
No surface representation
Hi guys
Im hoping somebody might be able to help me out with a basic enough meshing problem. I imported in a cad file of a plug flow reactor for the saponification of ethyl acetate reaction. When I try to run to run the mesh the program tells me that no surface representation is available for meshing. Any help is appreciated. |
April 19, 2016, 23:23 |
david
what mesh generation package are you using? in any case, you need surfaces for a 3d geometry. I would normally export my geom files as *.ACIS or *.SAT format. IGES too
April 20, 2016, 03:30 |
Hi David, thanks for your reply. I am using the thin prism layer polyhedral mesher, tthe geometry files were given as CAD files, how do you import in the other formats
April 20, 2016, 03:34 |
david
if it is a CAD file, it should be in some readable format that most CAD softwares are able to process. Use autoCAD or Solidworks for example and save the file as a format that your mesher is able to read.
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
2D Representation of surface values in 3D | mrurq | EnSight | 6 | February 25, 2016 05:01 |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 12:43 |
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin | Kaushik | FLUENT | 1 | May 8, 2000 06:47 |
