April 12, 2016, 12:14 |
time needed to run a a simulation
Alia Amer
Rep Power: 10 |
i am simulating internal and external air flow inside a building using ansys flotran. i have a total element number of 2.5 million elements and the file is 19 GB. it took me 12 hours to run 100 iterations... is this normal????? please advise me since i am afraid that something might be wrong with my simulations or set up!
April 15, 2016, 02:08 |
david
Rep Power: 13 |
run the simulations using more cores? My guess is you are using only one core for the calculations.
April 16, 2016, 07:58 |
Alia Amer
Rep Power: 10 |
what do you mean by more cores?
April 16, 2016, 08:15 |
Alex
Rep Power: 47 |
There is really not enough information to answer the initial question. Without knowing the hardware you ran the simulation on it is impossible to comment on the simulation time.
It might be normal on an old laptop or a machine with too little memory. It might be slow on a modern workstation. |
flotran, run, time |
Problem with an old Simulation | FrankW | CFX | 3 | February 8, 2016 04:28 |
Transient run continues from last time (when startover is desired) | bongbang | CFX | 2 | March 22, 2015 23:05 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 09:34 |
calculation diverge after continue to run | zhajingjing | OpenFOAM | 0 | April 28, 2010 04:35 |
Overflow problem in steady simulation | ReeKo | CFX | 11 | October 8, 2008 17:57 |
