I am new to Cfd. Please help to develop a MATLAB for this problem
Like Tree11Likes
  • 5 Post By mprinkey
  • 1 Post By FMDenaro
  • 1 Post By mprinkey
  • 3 Post By Alex C.
Old   April 23, 2016, 05:37
Default I am new to Cfd. Please help to develop a MATLAB for this problem
Priyanka
Priyanka Konakandla is on a distinguished road
A thin plate is initially at a uniform temperature of 200C. At a certain time t = 0 the
temperature of the east side of the plate is suddenly reduced to 0C. The other surface is
insulated. Use the explicit finite volume method in conjunction with a suitable time step size to
calculate the transient temperature distribution of the slab and compare it with the analytical
solution at time (i) t = 40 s, (ii) t = 80 s and (iii) t = 120 s. Comparison should be shown in a
graphical plot as well as in a tabular form showing the percentage error with the analytical
solution.
Recalculate the numerical solution using a time step size equal to the limit given by the stability
criteria (possibly 8 second or higher) for t = 40 s and compare the results with the analytical
solution.
Solve the problem using the both Crank-Nicholson scheme and fully implicit
scheme and compare the results with analytical results at (i) t = 40 s, (ii) t = 80 s and (iii)
t = 120 s.
With a time step of 8 s, compare the results of all these three schemes (explicit,
implicit and Crank-Nicholson) at time t = 40 s.
The data are: plate thickness L = 2 cm, thermal conductivity k = 10 W/m/K and C =
10x106 J/m3
/K.
Priyanka Konakandla is offline   Reply With Quote
Old   April 23, 2016, 09:28
Michael Prinkey
mprinkey will become famous soon enough
http://lmgtfy.com/?q=matlab+crank+nicholson
Is there a policy here about cutting and pasting homework problems? I honestly don't mind helping students with particular problems or questions, but these type of posts really annoy me. I am never going to be inclined to help someone who has clearly made zero initial effort. I suspect that most knowledgeable people here feel similarly.
So, are these reportable? If not, should they be?
mprinkey is offline   Reply With Quote
Old   April 23, 2016, 11:42
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
I agree.... perhaps someone could argue that a sub-section for homework requests could be an idea, too...
j_02 likes this.
FMDenaro is offline   Reply With Quote
Old   April 25, 2016, 07:08
Arjun
arjun will become famous soon enougharjun will become famous soon enough
Actually this is why i completely stopped visiting cfd online. I was contacted by many people about their masters or phds work and often found myself doing their thesis work. Like meshing and running simulations etc.
I stopped replying emails etc which asked for homework.
Asking on forum is some what forgivable because anyone can answer but still many times it shows that person did not do proper search or put proper effort.
arjun is offline   Reply With Quote
Old   April 25, 2016, 07:14
Priyanka
I am an undergraduate. How can you say that i put zero effect. I tried it.I also tried googe if it could help me out. I know that i am at zero level but everything starts from there. Help me if you can. If you are too busy then you can ignore the post. There is no compulsion that you have to answer every question posted. Thank you.
Old   April 25, 2016, 07:42
Michael Prinkey
I am an undergraduate. How can you say that i put zero effect. I tried it.I also tried googe if it could help me out. I know that i am at zero level but everything starts from there. Help me if you can. If you are too busy then you can ignore the post. There is no compulsion that you have to answer every question posted. Thank you. Your post is offensive
You cut and pasted the problem description from your instructor. You asked the forum to do your homework for you. This is not how you learn. If you had asked, "What is the difference between fully implicit and Crank Nicholson?" or "I've implemented this matlab code but it doesn't work...what am I doing wrong?" I and others would likely have helped you.
But you didn't. You took TWO problems exactly as issued by your instructor and posted them on a forum filled with highly competent CFD researchers and practitioners and asked them to think for you. If I were your instructor and saw your post, I would give you zero credit for whatever assignment you turned in.
FMDenaro likes this.
Old   April 25, 2016, 07:55
solution.
solution.
t = 120 s.
10x106 J/m3
/K.
this is just a homework ....
mprinkey likes this.
Old   April 25, 2016, 09:02
Alex C. is on a distinguished road
I found this presentation by googling your statement. Slide 13 is an exact match. What you ask is basically plagiarism.
mprinkey, tas38 and FMDenaro like this.
Alex C. is offline   Reply With Quote
Problem regarding producing streamlines from surfaces in Ansys CFD post gauthamnarayan Visualization & Post-Processing 0 April 23, 2015 16:07
CFD Online Celebrates 20 Years Online jola Site News & Announcements 22 January 31, 2015 00:30
CFD Problem Apoorv FLUENT 0 February 13, 2008 15:12
CFD - Trends and Perspectives Jonas Larsson Main CFD Forum 16 August 7, 1998 16:27
salary range Frank Muldoon Main CFD Forum 7 August 3, 1998 19:04
